Cruiser in question... 1976 FJ40, header.
So when I bought this thing the owner told me it had a back fire when shifting gears or when the idle droped quickly. I figgured no problem I can figure it out. Well After checking the timing and valve clearences I figgured it had a bad exhust valve. Pulled the head and took it to the machine shop they found a exhust valve that was not seating all the way. I had the head totally reconditioned. I put it all back together today, adjusted the valves and went out for a test drive. Guess what... the mother Fing pos still backfires! So I am a little irratated. On the up side I now have a new head gasket and a rebuilt head, but what is causing the backfiring? I did not install the headder the PO did and said the carb was re jetted. Where would you guys look next?
