Back in an 80 again, Locked this time
Thanks Jas. I thought yours was gold for some reason, didnt know you had a two-toner. Armor will come in due time.
Thanks Matt, yea I have a few goodies lying around, but could have used that husky liner set I sold a few months back or the gray tuff duck set, but oh well.... Hindsight is 20/20
Gonna go out and tackle the tank, will report back
Nope.. Not gold. :grinpimp:
J
Ah, I guess I forgot the two tone, definitely a good looking truck. what headlights are those? they dont look OEM. Or maybe they are just super shiny and clean!
And Operation Change Gas Tank was a success!! the :princess: went to the gas station and picked up some petrol. Once she returned, I added 5 gallons and turned the ignition. Took a little longer obviously as it was empty. I did a quick test drive, it drives nice.
Next up is to change out the front seats and change some fluids. Hope to get to these this weekend.
Here is the new one all ready to install.
Went to an inspection station today, it failed. License plate lights are out, missing a lug on each rim, wiper blades need replacing, and the water pump/alternator belt is fraying. Picked up the wipers, belts, oil/filter, coolant and 15 gallons of distilled water for a complete flush. I will order a MR T water pump, may as well replace that too while I have it apart.
Can someone confirm that there is just the 1 block drain plug on the driver side?
Thanks P.
Well, it was 2 steps forward 1 step back.
Oil change - check
swap front seats- check
change license plate lights (inspection) - check
wiper change (inspection) - check
Bad news- sadly, when I was changing the belt, the nipple on the top of the rad broke. i have another, but it will not be drivable this week until the water pump comes in. Once it does, I will change everything as well as do a full flush. se la vie'!!
hope everyone had a good holiday weekend.
I ended up ordering a new rad from Mr T, the all metal brass one so I dont have to do this again. It shipped today so hopefully I can get this done this weekend. Also, I ordered a PHH kit from Josh at AJIK- figured I would do that too while I am in there. Josh is a great guy BTW.
green grass hopper came over today to get some parts. he owns Land Cruiser Specialist, Austin's only full time cruiser shop. He is also an Ironman dealer, and brought me some goodies.
The LX I just picked up has a fuel pump that resembled the one you death with. Since you have have seen many as you part them out what does a normal one look like?
Yes, the should look like this http://www.cruiseryard.com/80-series-fuel-pump-assembly/
I have them and am local if you need one. Congrats on the LX, come to the meeting in January.
I ended up pulling one from a 96 at the Del Valle Wrench-a-part this morning. It got there on the 4th so it hasn't been picked through yet. Only thing missing was the rear 3rd. I pulled the rear axles and driver side front. Passenger side I assume was bent because I couldn't pull it out. It had some good front end damage.
Hey my favorite used parts dealer got another rig! Dibs on birfields...
Congrats! I know you have access to everything you need to make this one cherry!
@beno hmm, I thought the metal ones were had a metal top and bottom. if this isnt the case, what does the plastic one look like? I know there are 2 types. I should get it either today or monday and will post a pic of it.
@snack and tapage, you guys are too funny! Yes, the plan is the make this a nice truck. Of course there is a diesel conversion in the future too, with the 1HZ having a serious lead on any other engines. I love that yota diesel for some reason.
If you bought a Toyota radiator, and it is a 3 core brass, it will be 16400-66040 as the part number. (1993-1994 radiator).
It will have plastic top and bottom tanks.
Parts showed up today-
Water pump with gasket
Tstat with gasket
radiator
beno is correct (not that he woudlnt be!) the metal one still has plastic top and bottom. I'd like to see what an all plastic rad looks like if anyone is running one. But it sure does look purrtyy!
I need to find time to install them in this cold weather. My Ford's fuel bowl is leaking due to the ULSD- the ULSD causes the orings to lose elasticity in the cold weather, so I need rebuild the fuel bowl tonight.
Very nice Jason, very nice. The two tone is sharp.
Noticed 'Clifford' in your sig... I have a 2000 F250 and did the fuel bowl recently. Be VERY careful tightening the fuel pressure relief valve line back onto the bowl on reinstallation. I twisted mine off with very little torque applied. Upgraded to aftermarket unit but was a PIA to cut-off and re-flare end. Also had to wait a few more days for parts. Otherwise, pretty straight forward job. Have fun!
yea, got it done. I made sure not to over-tighten the FPR, I got them from dieselorings.com (excellent place btw) I called bob and asked him how tight to make the FPR after I read your post :) Everything went back fine. Amazing how gnarly some of those were- expected for 13 years.
as far as the 80, I installed the rad and water pump and tstat. And changed the drive belts. But when I removed the vbelt for the ac/crankshaft pulley, I saw it needed to be replaced so I got that at NAPA. Its warming up here so I may go out and tackle the flush and belt tonight.
