axle wrap mounted, will it work
Ivydale W.V.
I had to mount it at an angle to clear the shock, will it work at this angle with out binding up.
Tim
That will definitely bind on the axle end. Bushings are meant to pivot on one axis and mounted like that you've got them rotating in two.
Howdy! Mine is similar to that, but I have the fat end lower on the axle housing, and I have the shackle reversed from yours. It makes the anti-wrap bar parallel to, and just a tad bit lower than, the driveshaft. Just a little extra proteciton for the DS. John
Maybe it will, but if that was the case, then why do you have bushings instead of the wrap bar welded directly to the housing?
