Axle Weights?
Can't help you with the axle weight, but I lift 200s on two separate two post lifts pretty regularly at BudBuilt...
shoot for the rearward edge of the B pillar . That rear end is pretty heavy even when unloaded.
Thanks Taco. I've been measuring for layout of a 2 post and want to be sure I give myself enough room in all directions without taking up more space than needed.
That is a problem I wish to have some day.. congrats
The 2 lift points I use are just in front of the big crossmember where the frame starts to bend inward, and the rear control arm mounts.
Anyone have stock axle weight specs for a 2016? Not ratings but true weight on each axle.
Trying to determine true center of balance for lifting on a 2 post lift.
Maybe someone has had their truck axles weighed separately?
I had my 2014 LX weighed last week. First weight is stock wheel and tire upgrade only. LX tend to be a little heavier though.
