Axle Splatter Continues Need Help!
Hi all, I have a '97 LX450 with 210,000 miles. Replaced left front axle (birfield joint?) and new wheel bearings at around 196k. Lasted about one month before grease was gooping out all over the place under the left axle (ball wiper area). Took it to the dealership and spent 1k to have all axle seals and wiper assembly and hub replaced. Worked great for again about one month, then the outer hub started blowing grease all over the front of the wheel rim. Took it to dealership and they replaced the hub. Drove it another month and, blammo, green moly grease blown all over the garage floor and all over all the "new" axle (round ball area) bottom area. I am at my wits end. Dealership says they will cover it under warranty if a part is to blame, but I am thinking something deeper is at work here (some frame or steering component broken or worn out causing too much force on the front axle maybe?) Any thoughts would be appreciated. Have spent well over 3,500k now on this front axle but hate to risk the family's safety by leaving it unrepaired. TIA
is there any play in the wheel?
all bearings preloaded properly?
spindle bushing etc OK?
did you check to see if the axle shaft is straight?
is the wiper seal put in the correct side in (isn't there a lip issue or something?) ?
(random throw of utterly unrelated possibilities off the top of my head? :))
All good questions that I just don't have the mechanical expertise to answer. The axle was replaced by an independent shop, then when that started gushing grease I took it to the Lexus dealership (Longo) and they said they would replace the axle seal and the wiper seal, etc. but I don't think they took out the newly installed axle itself. I'll be sure to mention the items you noted to the mechanic when it goes back in for repair . . . because something has got to be either installed incorrectly or there is some serious force issues going on. The steering hasn't been right for the last 6 years (turns very hard and the wheels chirp and skip like its locked in 4 wheel drive) but every time I point this out all mechanics say everything looks okay to them! Arrggghh.
You have to remove the axle to replace the oil seal.
Get some of the new 'heavy duty' inner oil seals from marlin crawler or slee offroad.
Also, check the differential breather vent. remove it and replace with something better. It may not be the culprit, but if it isn't functioning it can cause a build up of pressure in the axle.
PS, your steering is fookered. It should not be doing that. Where are you located? Maybe one of our vendor shops that specializes in these trucks can help you out.
You've got to have problems at one or more of the following places:
1. The knuckle itself isn't sealed, and the grease is coming out of big gaps that shouldn't be there.
2. The inner axle is not sealed, and large amounts of oil are leaking into the knuckle and then dribbling oily grease through the wiper seals
I bet the problem is something closer to #2.
Is the green grease you're getting on your floor thick and viscous, or runny and oily?
If they just replaced the seal, and you're getting that quantity of oil leaking through already, then you've likely got something wrong with the axle itself. Bent?
You would have to have some serious issues at the knuckle housing to cause gaps large enough for fresh uncontaminated grease to flow out in quantity. Not sure.
If you could undertake a few greasy observations, we might be able to tell you more.
man, you've had trouble with the steering not being right for 6 years...? :eek: Skipping and chirping does not sound OK. Do you have a front locker? Did you check the alignment?
I don't know how Longo or anybody else for that matter could have changed the seal without removing the axle shaft (if that's what you meant). Maybe they just didn't change all the seals? I mentioned a bent axle shaft cuz that would likely also do a number on the axle seal perhaps very quickly.
yes, a useful clue would be the type of goop that comes out. Does it look like nice grease or is it runny soup?
The hard steering sound like the viscous coupler on the CDL might be frozen, thus not allowing the front and rear diffs to operate independently. That would cause hard steering and chirpping. My bet on the leak is that the breather vent is clogged and pushing oil out the inner seal as others have stated
Exactly what I thought.:) Good to know that I'm not totally brainless on Mondays.
TK
Thanks for all of your replies. I have made notes and will pass along to dealer mechanic in two weeks. The grease is fresh, thick and green and gooping out in half dollar size dollops (just like last time). I don't know what viscous coupler or CDL are, but I like hearing different ideas about root causes because the axle has been replaced along with all the hub, bearing and wiper ball parts so maybe this is the culprit. Also will check the breather vent. Also, while the steering is tight and chirping for sharp turns, the freeway feel of the steering wheel is loose (neither of which should be the case I know). Certainly feels nothing like when it was new and would turn on a dime. I've serviced this truck religiously and, while we take it to the snow every winter, have never done anything close to serious off roading so I don't think it is excessive wear. I'll keep you posted after this next go round. Thanks again!
if your grease is not runny soup, that suggests that the shaft seal is not letting large quantities of diff oil into the knuckle, which is the typical problem. So that seal may be good.
OTOH, for thick grease to come out so fast from the knuckle there has got to be something big missing. Do you see the wiper seal on the back of the knuckle? A thick seal covered by a narrow bolted on peripheral strip (IIRC)? That should be tight on the knuckle, with no big gap, leaving only a very thin layer of grease on the round ball. I can't see good grease coming out that fast if the seal is right.
(The grease is not coming out from a hole on top front, is it?)
(And especially not coming from the very bottom of the knuckle where there are 4 bolts and nuts together, is it? :eek: Btw, you better go and check all the bolts around the knuckles and rods for tightness in any case...)
Be sure to check the front diff breather. If it is clogged, the gear oil can heat up and the pressure will blow gear oil into the knuckle past the seal.
Please check this asap.......
(And especially not coming from the very bottom of the knuckle where there are 4 bolts and nuts together, is it? Btw, you better go and check all the bolts around the knuckles and rods for tightness in any case...)
check these out
https://forum.ih8mud.com/80-series-tech/247390-real-time-broken.html
https://forum.ih8mud.com/80-series-...needed-major-fluid-loss-steering-knuckle.html
https://forum.ih8mud.com/80-series-tech/229576-missing-bolts.html
https://forum.ih8mud.com/80-series-tech/231346-check-yer-nutz.html
WAG...maybe all the dealer has done is replace the felt wiper on the outside of the knuckle ball...and that the real issue is a leaking inner axle seal. Strip everything down to the inner axle seal, replace as per a standard knuckle rebuild and you should be good to go.
Or, they replaced the inner axle seal when they first did the $1K service, but did it badly. Since then they've just replaced the felt wiper.
The dealership just called to say that it was the inner axle seal that had blown out, again. They had replaced this same part last September and so I believe they are covering this under their one year parts warranty. I passed along all of the suggestions re: clogged breather vents, etc. but have not gotten any feedback from the Lexus technicians as to whether they felt this was a contributing factor. I also agree that the steering issue is a worn out viscous coupler (now that I have read up on the subject) -- as the symptoms are exactly what the book says the truck will do when the coupler is wearing out. Thanks again all for your help!
new inner seal blown out...?
rather unlikely I would think...
Unless it was damaged when they re-installed the axle.
I suppose. That would be pretty sad for a pro Tech, though... then again, nothing the dealers do will surprise me any more, unfortunately....
much more likely they didn't replace it earlier...
(and still, though, Jef said the grease coming out was thick and fresh looking IIRC, that does not jibe with oil intrusion....)
