Axle Splatter Continues Need Help!
Last fall I had a great shop fix my broken birf/front axle(didn't have the time). It started leaking about a month later, and since I needed to rebuild the front and replace the other birf(clicking bad, original with only 275 k on it), I took everything apart and lo and behold, no spring in the newly replaced axle seal. Never found it either. I was dissapointed, but glad I didn't take it back so they could screw it up more.
Got the truck back from the dealership today, no charge. This is actually the third time this inner seal should have been replaced. First, when I had an independent shop replace the front left axle, it lasted several months before the seal apparently blew out causing the thick grease goop. That shop then supposedly replaced it, but it blew out again a month later. That's when I took it to the dealership, where they replaced it last September, then it blew out a week ago and has now been replaced a third time. Add to that the wheel hub, bearings, and wiper assembly were also replaced so just about everything should be new in that front left axle area. I'm still not convinced (and I don't think the Lexus mechanic is either) that it is solely a seal issue, but rather something else going on but so far no one has had the "a ha" moment and pinpointed any other problem. I'll let you know how long this one lasts! Hate to keep having this issue crop up as the reliability of the engine and tranny on this truck has been superb and it gets used every day with 211,000 miles on it. Best regards.
