Axle seals and an overfilled diff
Atlanta, GA
Have had a pretty good run of luck with the 80 lately. Lots of miles and smiles - no problems. Having something minor and thought I would post up here - any help is appreciated.
In the last 2 years and 20k, drain and filled front diff. Repacked hubs and replaced wheel bearings. Greased where appropriate and tried to keep the front axle in good shape.
About 3 months and 2k miles ago, full brake service - rotors and pads. At that time, that shop I used mentioned that they had to replace an axle seal. Their mistake and they paid for the repeat service.
A few weeks ago, I noticed a slight noise. At low speeds (and only noticeable with the window down) I hear a slight rattle or strange noise. It isn't the axles clicking - it more sounds like if I had a metal hub cap that was rolling crooked. Doesn't sound bad, just different. Also, it isn't constant. It seems to change with the temp, humidity, and time driving. Just sounds like something is slightly off kilter.
Anyhow, I crawled under after hearing noise and saw the driver knuckle/ball had a little more grease than normal on it. Grease looked slightly grey and I could tell from the wear pattern on the ball that there was more grease in places the ball didn't rotate (I hope that makes sense).
At that point, I'm thinking seals failed somewhere and I am looking at rebuilding the axle. Took it into my guy today and just got off the phone. They said the front differential was slightly overfilled but everything else looked fine. The grease on the ball wasn't deemed to be excessive and there was no mention of the cause of the noise.
On the surface, this sounds great. No need to spend more money. However, I am worried about the front diff being so full. If it has been a few years since service, it doesn't make sense that it is still full - right? No water crossings or anything like that - have been locked up a few times in the woods but nothing exotic. Also, the grease on the ball has me slightly concerned.
Anyhow, long way of saying - any insight/ideas? I thought about taking it to ACC - those guys are awesome. Just worry that a trip to ACC might be overkill if I am describing something minor/normal. Thanks!
because of the placement of the fill hole and the way the fluid just runs out when overfilled i cant see how you would be able to overfill it. that being said id guess the breather is clogged so it sucked moly past the inner axle seal which caused it to have too much fluid in the diff..change the gear oil, clean the breather and call it good is what id do..
as to your noise i have no clue
Good call on the breather - totally forgot about that. Breather is stock, never been messed with.
1 banana job to extend?
As for the noise, I drove again today. It almost sounds the way the passenger mirror glass sounds when loose. Except it is coming from wheel well.
Thanks!
Thanks!
Do you have the Toyota center caps on the wheels?
You stated that an axle seal was replaced during brake service. What makes more sense is that the hub seals were replaced. To replace an axle seal the knuckle would have to be broken down and the birfield would have to be pulled.
When gear oil gets old and contaminated or mixes with grease from the knuckle it can foam and expand. I don't think the amount of grease itself is the reason it was overfilled. A photo of the grease on the ball would be helpful. Everybody has a different description of what looks normal. Have you checked the grease level in the knuckle through the square plug?
If the noise is more of a rattle I would look at rocks in between the dust shield and rotor or the brake pad hardware might not be in proper position. Taking the wheel off and inspecting should be your first step.
We need pictures I am lost at the grease out side and the replacement of a axle seal, I think there maybe more to the story or not
Agreed, a Photo says 1000 words.
There should be some grease on the knuckle ball, but not an oily sloppy mess.
I routinely over fill my diffs by up to 500ml, a slightly high oil level is not a problem in itself.
+1 on checking breather valve is clear
+1 on checking for rocks, or minor damage to the brake dust shield
No on the Toyota center caps. Have American Racing Wheels - will snap a few pics.
I'm definitely a novice, so my seal/axle knowledge is limited. Very well could have been a hub. I cleaned up the knuckles after bringing truck home, will drive a few miles and see if the grease patterns return. I have seen some nasty knuckles on this site - mine was not like that. Just a little more grease on one side than the other - I have been conditioned to worry about my birfs!
Thanks for all the replies. About to leave on a hunting trip - will report back after I return. Thanks!
