I have to tear into the axles this weekend to check/tighten the wheel bearings. Does any one know the part #s of the seals I will need?
When you say "check/tighten the wheel bearings," do you mean the bearing preload? If I'm assuming correctly, then you don't need to tear into the birfield area like you would to repack. Might be an opportune time to repack if you are indeed going this route.
Seals, etc:
90311-62001 Grease seals for wheel
90215-42025 Tabbed Spindle Lock Washer
43422-60060 Hub Gasket
If you want to replace the bearings:
90368-49084-77 Inner wheel bearings, Timken bearing #JLM104948, race #JLM104910
90368-45087-77 Outer wheel bearings, Timken bearing #LM102949, race #LM102910
Seals, etc:
