Axle/Knuckle Removal Question
Whitinsville, MA
I am going to be pulling my drum brake 74 axle apart to prep it for sand blasting. Can I undo the steering arms and the part under the knuncke and just pull the kunckle off with the axle and all? I just don't want to get into tearing everything apart at this point becuase I don't want have all the pieces laying around. I will be doing a disk brake conversion with a FJ62 axle when I do finally rebuild.
Yes I am planning on getting FSM but only have a Haynes manual at this point and it appears thatit will work.
Yeah, you can. Pull the hub cover off so you can remove the Clip on the birf, then pull the steering knuckle and brake line and it should slide the entire outer off.
Very quick way to change a birfield also.
Why in the world do you want to sand blast the axle? Scape/wirebrush and paint black. By your question it is apparent you have never sandblasted anything. Sand gets absolutely everywhere...especially places you don't want and is hardly the right thing to promote a long life of the internal components of an axle. It will get everywhere despite best intentions and precautions. Then you got a mess on your hands.
Okay looks as if I wasn't clear enough. This isn't a running and driving cruiser its one that I am resurecting. My thought was to remove the axles and brakes, stuff something in the houseing and tape the ball off with duct tape and heavy duty plastic. Have a guy who is going to sandblast my frame for free so I was going to try to get the axles sandblasted now instead of later to save having to pay someone in the future. I am going to rebuild the knuckles when done using and FJ62 knuckles I picked up for the disk brakes.
dgangle I have never personally sandblasted anything so no I wouldn't know. Did you know eveything the first time you rebuilt a vehicle? (Not trying to sound like a jerk)
Should I take the diff out? If I don't what should I look at replacing?
Noah/Jutty, thanks for the input. I figured that I could take the knuckles off the drum brake axle since I have the complete FJ62 which I won't take apart until I am ready to rebuild the axle.
in my opinion this may be more trouble than it is worth. Looking at your situation I would personally do the following, as I too am right in the middle of a minitruck disc swap and wish I had done it different:
- pull apart the cruiser axles
- pull apart the fj62 axles
- take everything you are going to put on the new truck adn get it hot dipped and/or sandblasted.
I wish I had done this as I spent hours and hours cleaning mtruck knuckles and parts with kerosene, a pain in the ass. Plus many more hours cleaning out the cruiser axles. The diffs you may have to do by hand. The next build I plan to do the above by taking it all to one location and having them give me back clean parts that I can quickly prep with some brake cleaner and paint. Hope that helps.
Noah
...I wish I had done this as I spent hours and hours cleaning mtruck knuckles and parts with kerosene, a pain in the ass. Plus many more hours cleaning out the cruiser axles...
That's the fun of it!! How better can one understand all the intricacies and how it is designed, works, fits together,etc???? And use gaso....I mean pink parts washing fluid. It works sooo much better.
gasoline, will try that next time.
to clarify, I didn't mind taking the stuff apart and seeing how it goes together. It is just the massive amounts of gunk that was impossible to get at. Next time, FOR SURE, all that minitruck stuff and the axle housing, bolts, etc are all going to a hot dipper for the night, period.
Noah
Thanks for the additional input guys. I don't even know where I would go to get something hot tanked. I ended tearing front down to the housing. The front diff looked like it was in good shape. I threw it into a 5 gal bucket with a cover to store it and keep it clean. The shafts look like they are in good shape too. Boy that was a messy job.
I would tear the 62 axle apart but I don't think I will have the time before this weekend. Tonight I am planning on stripping the rear diff down to the housing.
Two questions:
1. To remove the knuckle I could only get to the 4 bolts on the steering arm and 2 on the lower bearing retainer. How to you get the other two off and remove it to take the knuckle off? I tried to take the backing plate off knuckle but it wouldn't budge. I'm asking because it looks like i will have the same problem with the 62 axle.
2. There is still a good amount of sludge in the axle and I want to clean it. I was thinking about hitting it with brake clean then pressure washing it. Any other ideas?
