If you have been following my newbie thread, you know I am trying to build an FJ40.
I have a 1975 with a SBC that was a SOA modification. When I had a shop switch it back they left the added perches in the axle. I had no idea what that meant but I am learning. The SOA mod also flopped the shock mount and added an arm to the top of the right knuckle arm. Looks butchered and I bought with the SOA already done.
The OME shocks do not line up because the shock mounts were cut off and flipped.
I decided to buy an axle and just rebuild it using my knuckles and gears (I guess it’s called a third member?).
I have a 1975 and have no idea what year this axle is that I bought. Are there any axle housing that are not compatible. Again I have a 1975 and the one I bought has drum brakes so it should be older than mine. I plan on using my 1975 gears, knuckles and axles in the axle that I bought.
Thoughts?
I keep getting beat up for not posting pics. So here you go...
Thoughts?
