Axle build with ram assist
Divide, Colorado
I have been planning on building a front axle to swap mine out with and the time has come to get it done since mine is now bent.
I have a stock FJ60 axle that I am going to start tearing down tonight. Here is a list of what I have.
1) 30 spline Longfields.
2) Longfield hub gears.
3) Front Range Off-road hub studs.
4) Knuckle rebuild kit from Marlin.
5) Axle gusset kit from Marlin.
6) Spring perchs from Ruff Stuff.
I will do the C&T since I am already sprung over. I am planning on doing a ram assist at the same time but havn't order parts for that yet. The work is straight forward enough but I would like inputs on what to watch out for while doing the build, helpful hints and suggestions on additional items I may be over looking.
:flipoff2:
For the trussing, how do you plan to keep the housing from warping?
Weld and in/let cool & repeat a billion times, build some type of jig, ????
I have a suspected bent front 60 housing and have a spare laying in the trailer. When I swap them out, I want to truss it along with knuckle ball gussets to add some beef, but am a little worried about warping the housing.
X2 I have the same concern for a 60 axle I am working on. I would like to hear some input from others who have done this already.
Don
I already have the 4X4 labs high steer that puts the tie rod behind the axle. The rod ends are GM 1 tons ends.
I am planning on doing the stitch welding with cooling time in between to get the gussets installed. This is hard for me since I tend to push forward when working on something.
I was thinking of putting the 5th stud on the steering arms.
I tend to pay tuition to the school of Hard Knocks Learning so any idea's or tips would be appriciated.
Pictures of last nights progress.
lookin good Chuck!
Marlin HD Inner Seals, Cromo knuckle studs, and those new HDPE seals that take the place of the rubber/felt's would be the way to go. i dont know who make those, but we put a set on randy's pickup out at the shop and they look cool!
Pretty Penny is getting some BLING ;)
Still need to weld the drain plug shut.
I tried to order the seals from Longfield but the ordering process does not seem to be working correctly. I will have to give them a call tomorrow.
I was told that the diff armor from Marlin can be fit to the FJ60. Has anyone done this?
The cut and turn is done and the drain hole filled in.
Sounds like my parts are being delayed by a week. I don't expect to have the knuckle rebuild parts and the axle ball gussets in until the first week in February.:mad:
I still need to remove the bent axle and tear it down so that will take a good part of this week since I only get short amounts of time between work and helping kids with home work.
I welded the drail plug shut because I keep grinding off whatever I weld on to protect the drain plug. I have the low profile plug that is currently getting ground off. I will use a bolt in the bottom stud of the diff to use as a drain and I can always suck the lube out the fill hole.
FJ40FORLIFE,
Looks good!
Looks like your truss is a tube with a gusset plate is that correct?
If so it seems like a good way to go.
I added the same kind of diff protection to the rear axle diff cover but I am thinking I need something a little stronger for the front. I made a football helmet style protector of the front of the old axle and it is pretty bent up and ground off and that was only on for one year.
I was drinking a couple of beers thinking of what to do about diff protection. I wasn't coming up with anything. I had a friend show up and after a couple of more beers he suggested cutting the center of the bent axle and using it as a diff protector.
I welded a 1/2" steel rod to the diff, cut a 1 3/4" hole around the fill plug so I could weld a 1 3/4" piece of tube around it. I like the way it turned out.
Finally the spring perches came in so I made some progress.
The perches and gussets are installed. The axle is currently installed and painted. I still need to fab up the anti-wrap bar mounts. When that's done I can install the truss.
