axel issues, need help!
OKLAHOMA cITY
Howdy all!
Two weeks ago is did some off road in Arkansas, did high water mark trail. Good times! Im not sure if this had anything to do with my issues, but thought I'd throw it out there.
So now, I was having problems with my brakes, and realized it was because the drivers side front wheel was loose. I took off the wheel and found the axle clip was off, and when I looked further, the spindle nuts where loose.
I tightened everything back up, put it back together and all was good. Just about 40 miles later, eveything is loose again.
Any ideas? I will post more info and pics when I get the wheel off again.
thanks
P.S.
pics of "High Water Mark"
What do you have securing the spindle nuts? If they keep backing out I'd suspect that!
I would suspect that your wheel bearings are not in good condition, and your spindle may be worn at the bearing badly.
Great pics of HWMT. My son and I did it this spring. Truly beautiful.
Did you follow the proper procedure(s) to properly torquing the inner & outer axle nuts? Torque down the inner one to 43ft-lbs to seat the wheel bearings and hub and rotate a few times in each direction, back off nut, re-tighten to 40 INCH-lbs, then lock ring, then lock nut to 43 ft-lbs. There are a few opinions on how tight to do the inner nut, so use your judgement. I prefer to go a tad tighter.
Ok, wheel apart,
the outer bearing had gone bad. put new one in, luckily local shop had on on shelf.
wheel went together way better than when i tightened it all up the other day. hopefully that was all it was.
BTW. if your are in Arkansas, check out "High water mark"
here is the GPX link
