LX_TREME said:AHA!!! You mean like that down below???![]()
Screw Arnold![]()
Man. If only I could drink beer and selectively kill the brain cells that will remember those photos. Ughhhh....
Screw Arnold![]()
tabraha said:350 ft-lbs at the wheels![]()
What kind of drivetrain % loss do you think we have being full-time 4wd?
20-25% (420-440 ft-lbs) Then bring that bad boy down to me at ~500ft,![]()
That is VERY nice Christo.
edit: just noticed RWHP, so figure what 15-20%? Still, super sweet and with good looking curves.
cruisermaine said:I would think if it wasn't a 4 wheel dyno, it isn't really an accurate indication of power /torque at the wheels. Didn't you remove about half of the driveline losses? I thought there were some 4 wheel dynos around Denver thinking back to my Audi S4 days (lot's of modded S4's in CO)
And yeah i might agree with the autotranny.
LX_TREME said:Nice...Ahmed... who made those piping? Or come along with the Turbo kit?
By the way, are you the one with the 500hp white 80 series from Dubai?![]()
UAEGUY said:This car was running stock ECU with additional injectors and fuel cut difencer from HKS and i can boost the car to 14PSI with out any problem with the shown turbo.
UAEGUY said:Hi there
This is Ahmed from United Arab Emirates – Dubai it is nice to see some guys interesting to pump the power on those V8 motors.
First of all, please excuse my poor English it is not my first language.
Sleeoffroad I have some info and I want to share it with you it may help you in your project
Wile back in 98 I was the first guy in UAE who owned a V8 Landcruiser Turbo and you know how is hard to find some parts to complete your project for a new car, I sent some parts for some Manufacturer in USA and AUS to get the part done like low compression pistons and Crower Con Rod.
The first time I was running an extra two injectors before the throttle body but we face a problem the last two pistons #7 & # 8 broke because we was running lean, then I contact Ray Hall In AUS and he send me a biggy back computer- Autronic which is solved the problems. So you don't need that extra injector's just use a biggy back computer and that’s it.
Auto tranny….you can run the turbo with 5 psi with out any problems but if you go more the tranny will not hold.
The weak things in the Toyota V8 motor are the pistons and the Con rode they will not hold for long time so for any buddy looking for more post change those things first.
UAEGUY said:The car was manual, and i changed the 5th gear with low ratio
This is the link
http://www.autospeed.com/cms/article.html?&A=0950
Thats right the diff. was 1000 RPM which means you got more speed but the RPM will be the same.hdj105 said:Ahmed,
Could you tell me more about you changing 5th gear?
What did you do - I would guess you made it taller ratio to lower rpm to give you a better top speed?
