Aux Wiring help
Sandy Utah area
Im wiring up a light bar and I need help with my wiring. Can someone check this for me.
My goal is to use a relay and a switch I already have but to have the light be ignition hot only. Right now I have on the diagram the SLEE low beam jumper as a the triger for the relay but I am open to other options as I wont have time to get it from them at a reasonable cost before my trip. Any other suggestions for what wires I could tap into? I don't want to tap into anything vital without a jumper for the sake of removing it later or fouling up that system with moisture intrusion.
I have the Slee harness. Triggers are HB and LB, since you're looking for IG switched, it's not applicable. If you want IG switched, you'll have to pull from a different source. Pick a fused source under the dash that's IG switched, any will work.
I wouldn't get the entire Slee Harness, I will be wiring up my own, the only point of the LBJ is to splice into an power source without having to mess with the factory harness.
If you want to skip the IG switched, you can use the AUX harness. I see no advantage to having an AUX light ignition switched. However, when I add RIgid D2 DOT fog lights they will be wired to come on automatically with Low Beams.
You don't have to mess with factory anything for aux lights, just pull the hot from the relay. If you want IG switched pull the hot for the switch from an IG switched source from the dash.
Yeah, thats what Im trying to avoid, I figured a nice neat jumper would get me the hot for the IG without having to splice. That being said...is there anything under the dash thats easy to access for IG aside from the cig (already being used for another relay)?
Just use the cig for both. Relay current draw is insignificant.
Cool beans, makes it easier and cleaner and my relay draw line is fused already so it should prevent any issues in the event there happens to be too much draw on the splice. Does the diagram otherwise look right to you?
Typical automotive relay coil draw is on the order of 100's of mA, there should be zero issues with that setup.
As for the diagram, run the ground for the light bar back to the relay, tie into relay ground, and ground relay at battery terminal. I highly suggest just getting a harness as building your own requires a number of splices. You can buy the corresponding connector from amazon for that rigid harness which allows you to simply plug your light bar into it for ~4$ which puts you at <30$ for the whole setup. I have 3 sets of light running the rigid harness, zero problems.
I just heard back from Christo and they don't even have the jumpers anymore...FYI
