Aux Light Switch Part #
Gilbert, AZ
I see from previous posts that many have asked, but none have gotten an answer. So here it goes again...
What is the part # for this switch...
If you're interested in getting one you should be able to get something similar locally from Cdan, Christo, or someone abroad... like yours truly.;)
That particular one, I was told, that it might be for the rear fog switch.
But the (front) fog switch is just about the same, just facing the opposite direction and with the light shining down.:)
Slee's Part no. is TOY1009
It is an OEM toyota switch, as mot said it looks slightly diff than your pic (just the graphic)
I just installed the Slee headlight harness, Aux light harness and switch last night. Placed it over the mirror contol and illuminated via the reostat as per the instructions. Works awsome. I wired mine so the highbeam switch controls the driving lamps (when they are enabled by the switch in question).
I realize Slee and CDan can get this switch. I prefer to source it through my local dealership though since I am only after the switch (not the harness) I should have clarified this in my original post.
PM Dan, I am sure, if he does not know it off the top of his head he would be willing to push a couple of buttons and get it for you.
Make sure you post it in this thread, for future searchers.
Edit: Looking at the switch you have pictured, I am thinking the problem with sourcing the part number is because that is the switch for the "bun toaster" (stock on German Spec. 80s).
Pretty sure it is for the aux lights found on non-US models. I stole the pic from some other threads that discussed the switch.
Not sure why it is such a secret! :D
Thanks for the offer, Mot. I have been going through a buddy of mine that works for Toyota in New Zealand for the non-US parts that I get requests for. Although I always try to use a local dealer, due to price (shop discount), convenience and to avoid freight costs.
Good catch on the direction of the light icon.
What are you doing then if you're looking for only the switch and not the harness? I had one of these switches that I found in a 93 I acquired, though it must've been added as there was no matching harness or wiring... Anyway, I attempted to locate a harness for it and could not find anyone willing to sell me just the harness...
-Ferg-
It took me a bunch of research and I eventually had a friend smuggle out a JDM microfiche so I could figure it out and then I had to get the number loaded ( they won't do that any more by the way :mad: ) . The entire process took several months.
And you want me to cough-up the part number? :eek:
84160-60030................:flipoff2:
JDM on top left
Does anyone have a part number for the mating connector to switch part number 652399? :meh:
I guess I am surprised I can get these in the states but I can not get a matching connector
Not sure where you got this part number? Part numbers usually look like this: 84160‑60030 (front fog switch ToyoDIY.com ). Most of the connector styles are rather ubiquitous throughout Toyotas of similar years, so I usually just take a new switch to a bone yard and rip a mating connector (pigtail) out of a junked car.
Tercel (including wagon), vans, Lexus (like ES300), 4Runner, Tacoma, etc. Look for matching socket and wires in socket can be swapped in and out of correct positions. Cheapest way to go for a 91-94 fog switch is to get a used defog switch and pigtail and make your own fog label https://forum.ih8mud.com/80-series-tech/274776-switch-relables-printable-single-sheet.html , if you care to.
My bad, wrong past buffer
Part number 84160-60030
Looking for the mating connector number
Yes I searched and there are many part numbers for connectors but I found nothing to tell me specifically the part number for the mate to the number I posted. :meh: What am I missing?
