I want to mount a back-up light on the rear rail of my roofrack, so i can actually see stuff when i'm backing up. Problem is that i will take my roofrack off from time to time. Mostly in the summer when taking long road trips to cut back on wind noise and get better gas mileage, and just to wash and wax the roof. Anyways, i was thinking i would like to run a wire, drill a hole in the roof as far back as possible, install a rubber grommet type thing, run the wiring through the grommet and put some silicon on the grommet to make it water tight. THen put a nice little disconnect so i can connect and disconnect the rear back up light depending on if the rack is on or not. Basically it would be a little plug. Has anyone done this? And could i see a pic or two?
Thanks,
Alex
Thanks,
Alex
Josh
