I was following LandTank direction to enable Auto Window up as seen in this thred
https://forum.ih8mud.com/showthread.php?t=15277
I took a part the switches and clean a lot of black staff out of there.
After soldering the diods, the auto up and auto down worked, once!.
The problem I am having is that once the window closed, I can operate the window until I restart the engine.
I suspect it is something with the direction of the diods. One the silk screen it shows the vertical line. The guy at the electronic shop said that the line on the diod should match the line on the silk screen.
But Riches picture shows the line to the left. If I follow the silk screen picture the line should be on the right.
We have 10 degrees out there and i need the window to operate correctly. I appriciate any help I can get on this.
Rami
Rami
