Auto Trans not going into first while driving
sbman
Supporting Vendor
Julian, CA
I'm having an issue with the auto trans in my 1997 FZJ80 not going into first while driving. It is fine when first selecting 'D' and then it shifts normally with kick downs, shift ups, and torque converter lock/unlock and no slipping. When I come to a complete stop however, it often does not go into first, it seems to be in neutral. Giving it a little gas or just waiting and it will suddenly 'thunk' into gear, but sometimes just waiting doesn't work. It seems to be worse if I make a slow gradual stop, if I stop quickly and fully it usually is in first gear. If I make a rolling stop, it is much more frequent that it is neutral instead of first or even second. It makes it unsafe in traffic. It only does it from higher speeds, it seems like it's only when coming from 35+ mph at slower speeds it seems to reliably go into first.
I've done the following:
  • Searched the forums for solutions
  • Read the FSM
  • Adjusted trans throttle cable
  • Adjusted throttle cable from accelerator pedal
  • Gotten frustrated
  • Hate on automatics
The FSM says two possible things are wrong, the 2nd brake or the a shift valve. I don't have any of the other symptoms of either however. I can get engine braking in first or second just fine.
There are no codes thrown.
I would think that is it where a shift valve (bad solenoid) it would never clunk in to gear. you might try adjusting the TPS. there is an idle circuit switch that tells it is home (below 12.5%). do you have any type of box for speedo correction? they can introduce a slight delay but typically in quicker change inputs not the slower.
ever changed or flushed the trans? shift solenoids could be a little gummed up and moving slow. a transGo shift kit will help flow and pressure for firmer faster shift
The fluid is fresh, the trans was out of the vehicle. I drained and refilled the torque converter and replaced the front seal on it.
Unfortunately I don't know if it did this before or not, I was not able to drive it when I bought it due to a bad engine. Everything else is stock tires, gears, etc... The TPS is showing 11.75% when foot off accelerator and I don't see any lag or sticking in the data when watching it real time. I did check the TPS adjustment when I rebuilt the engine.
While driving around, it is fine in all gears and shifts except low speed shift down. It's hard to see a pattern to it though. It appears that it's only when coming down from third that it is having a problem. If I use the '2' selection in traffic it goes between 1/2 up/down just fine. If I do the same in 'D' the problem starts and I end up stuck in neutral part of the time. When it's 'stuck' in neutral, even moving the selector doesn't get it to drop into gear, you just have to play with the throttle till it decides to drop back in.
Does anyone know if there is a PID in the OBD data anywhere that indicates what gear the transmission is actually in?
If manually shifted down to 2nd or 1st then it has to be mechanical in the trans. You can disconnect the electronics and get it to move in 1st and 3rd based shift lever. 1st and 2nd mechanically defaults to 1st and 3rd is 3rd with no inputs. Is it in neutral or third with lots of slip very little forward motion but a little?
3rd gear accumulator sticking? Or a check valve ball in the wrong place in the valve body. I've been in my vb and trans once but am no expert to the internal workings.
When it's doing it, it is in neutral, no forward motion at all, or attempt of motion. I have to be easy on the throttle when it's doing it because it will slam into first no matter the RPM when it finally engages. I didn't understand your first statement. If I put it in in 1 or 2 on the selector, it works fine, and downshifts normally, it seems 100% of the time. It's only in 'D' that I have the problem. Once it is exhibiting the behavior though, selecting '1' does not force it into gear.
that's what i'm saying it should shift to 1st if you manually move the lever. some say there is an RMP/Speed that it will override. i've never tested at extreme rpm's it always goes there when i shift. even with no solenoids activated while i was messing with my tune. electronically there is no neutral neutral is a physical shift point i really think it's something int he valve body associated with 3rd gear. when in second electronically it moves between 1st and 2nd. meaning both shift solenoids are working. if its slipping its stuck in-between shifts fluid isn't moving to the right clutch packs. what was done to the transmission while it was apart?
I played with it some more today. I tried driving around with the PWR button depressed. No change. Then I tried second gear start and the same issue occurs, it goes into 'neutral' when coming to a stop from any speed that reaches third gear or above. It seems to be worse if I go faster and then slow down. Putting it into first manually has no effect. It doesn't feel like it's slipping, it free-revs exactly as if it was in neutral or park.
The transmission was removed from the vehicle, and then re-installed, it wasn't opened up. The only thing that changed was I pulled the torque converter off, drained it and re-filled it. I put a new main seal on and re-installed the torque converter. I've adjusted the transmission throttle cable per the FSM and also tried it looser and tighter than the FSM procedure, it works the same in all positions. As for RPM, when it finally goes into gear, it dumps it into gear no matter what the rpm, in fact it seems to be more reliable if I give it 1500+ RPM, but then the engagement is very harsh of course. I was hoping it was just some kind of adjustment, but from what you are saying and everything I've read in the FSM it sounds internal. I just need this thing to work for three or four months and I don't want to spend any money on it. I think I'll dump a can of seafoam in it.
i wonder if your loosing pressure at higher speeds? the torque converter has 3 engagement points. the pump is the last that drives off the 2 prongs on the snout that slides over the input shaft. if that was not seated there could be damage to the pump it only engages about a 1/4" i remember taking mine on and off several times and trying several times to get it fully engaged. i also broke the alignment hub off the front end of the converter so i had issues around that as well. i paid a lot of attention with the repaired converter and took a lot of measurements and took the front gear assembly out as well as the pump to check for damage. it's a pain to get everything aligned and fully seated. adjusting the trans cable you should notice a big change in firmness of shifts if not your struggling to build trans pressure and it is probably really smooth plush shifts all the time. unfortunately these are old school trans and do not have rail pressure sensors to help diagnose. the 80's go the most basic electronically controlled trans there are the A343F evolved in the 100 Series to add a lot of functionality
Stupid thought but you mention you removed the trans., so maybe when putting it back your shifter linkage adjustment is a little off.
sounds like you have done a decent amount of troubleshooting. check the linkage. unless you are sure the fluid was recently changed I would do a flush. otherwise, trannies are very complex and really require specialization, way above the level of the average shadetree mechanic. I would contact @orangefj45 Georg is a cruiser guru in Stockton and started out working on transmissions. See if he can diagnose it for you. worst case, you need a replacement. I have a low mileage one if you do need to go that route, but hopefully not for your sake.
throttle cable from the gas pedal. It's likely hanging up a little so that the closed position sensor in the TPS is not being closed when you take your foot off the gas pedal. Best solution is to replace the cable and make sure that the throttle body is closing fully when done.
Does the sheathing of the cable look beat up?
I spend quite a bit of time getting the torque converter on. Thankfully the FSM has measurements for checking if it's fully inserted. I went four tries before it was fully seated.
I checked that.
The cable is beat up, but the TPS value in the ECU is correct.
It really sounded like something internal. I poured in some seafoam 'trans tune' and drove it around with basically nothing to lose, if it did nothing or made it worse, the trans still needed to come out. After the first mile the problem started going away. After 3 miles, it was gone entirely. Driven it for two days and it's working 100%. Something was stuck in there somewhere and a little solvent freed it up. I'm happy for now and if it works for a few months, that's all I need. Going to drain out fluid this weekend and refill to dilute out the seafoam stuff.
Is you 2nd Start button pushed on the console? Maybe bypassed and stays on?
Good to hear. If you continue to have trouble I'd drop the pan and clean things up. Do a shift kit it's $100 and at that point t you take the accumulates out and check those out too. I replaced my valve body gasket while I was in there
