aussie locker?
Topeka, Kansas
This question goes out to you guys that have an Aussie locker installed on your DD's. Do you have any issues under normal driving (road) conditions that you did not have before installed? I have been told I won't like the way it turns, and will have a loud *pop* around corners. Would just like to hear from someone who actually has one installed and drives it regularly. Thanks.
My rig is my DD, some clicking when going slow and turning. Not a big deal, the advantages of it far out weigh the noise issue.
When I was still full time 4wd I almost never noticed the aussie. I could hear a slight clicking with the window down at a drive through, but it never popped. Now that I am part time it is more noticeable and will pop occasionally going around a corner, but I have not considered getting rid of it.
This has been discussed and reviewed thoroughly in various posts, but the unanimous verdict is:
- In a full-time 4wd 80-series, the Aussie Locker is virtually transparent on the road.
- Ratcheting is the the only common noise, with the very occasional pop or clank.
- Truck handling is unaffected.
I've been running an Aussie for three+ years now, and I can attest to the above personally.
x2. It's a great locker that performs well when needed.
This is probly a dumb question but if I put an aussie locker in with the stock gears and then decide to regear to something like 4.88, will I have to buy a new locker. Go ahead. Im ready. Please be gentle.
I get occasional popping. I'm also PT4WD. When I had full-time there was no popping.
No.
no, the ring gear and locker unit are separate units that are bolted together, I would recommend doing these two modifications together because to replace either of these units the whole diff has to be dropped and 90% of its contents need to be removed. just save up buy both units and only pay one set of labor charges for r & r
I respectfully disagree with this one.
More like 20% of the contents removed--namely the side and spider gears and cross shaft. You don't touch the ring or pinon gears, or any bearings, and you don't have to worry about backlash or "setting up the gears" like you do when you install new r&ps. Measuring and adjusting the tolerances with the Aussie install is easy and straightforward, with no specialized tools.
It's a piece of cake to install an Aussie Locker, and there is no reason to wait for gears--just get your Aussie and install it yourself. It's easy.
:beer:
you might be right because I have never done a swap on the 80 series, but some of the other diff units I have rebuilt like the one on my sc430 need the whole carrier to be removed to access the ring and pinion and also to install the limited slip unit.
this is what had to be done for my sc :-\
3.76 Supra LSD Differential DIY -- SC430-- - Club Lexus Forums
Yeah, you don't have to touch the carrier.
More or less:
1. Drop the 3rd
2. Pull out the cross shaft and spider gears.
3. Remove the side gears.
4. Put in the Aussie locker.
5. Replace cross shaft.
6. Put the 3rd back.
You have to check some tolerances in the Aussie with feeler and dial gauges, but tweaking is merely a matter of using different thrust washers.
https://forum.ih8mud.com/80-series-tech/118690-aussie-locker-install.html
Sweet.
Yeah, looks you put in some kind of Torsen? I did a Trutrac in the front end of my 80 last year, and I paid somebody to do that along with new 4.88 gears (I pulled and delivered the thirds). Under these circumstances it DEFINITELY makes sense to do them at the same time--the factory carrier is replaced, so you have to pull the ring gear regardless.
The Aussie Locker is a "lunchbox" locker that fits inside the factory carrier. You only remove one bolt--the one that keeps the cross shaft in place. The fact that I already had the Aussie in the rear diff made no difference to the guy who did my 4.88 gears--he just pulled the ring off the carrier and adjusted the backlash between the r&p after putting in the new gears.
Thanks, for the help! This will be my next project. I did see a listing on Torque masters website for a front kit also......does anyone have these front & back?
x2
you will get some overstear when powering your rig around a corner. But heck you should be driving your cruiser like a corvette. :D
I would do mine again in a heartbeat. I'm very pleased and the extra traction offroad is killer!
:cheers:
Like everyone else said.
Best bang for buck.
It will open up a whole other world of off roadn and getting stuck:cool:
I've been running my Aussie since Dec. 05 IIRC. I have never had an issue with it and my rig is and always has been my daily driver.
I get very minor clicking in parking lots when I make a tight turn into a space. I got it to pop once on a wet road when I took a hard right turn and punched it in the turn. Make sure you run heavy oil in the rear. That cuts down on some of the clicking noise.
You definitely DON'T want to run one of these in the front end of a full-time 4WD rig like an 80-series. Rear only, unless you convert to a part time transfer case and selectable hubs.
quick questions
when we say dd-how many miles are you putting on your truck per year?
extra maintenance for the diff.?
expected longevity of the locker?-read 50k somewhere.
what is the actual part number?
thanks
tl
