Yes, but pull them all the way out. No reason to not to.I cant find my FSM section for the rear diff. Do i have to pull the axles out a few inches? I thought I do......
How is your gap tolerance? Is it in Aussie spec? You will have a bit more clunk if you change drive to reverse quickly or via versa.Now I have a drive line clunk and ping when I put it in reverse and drive. dang it
.019 and .150 are within spec.
I took time to cycle through a long series of full brake transitions. Its there regardless. I tried tightening the DS bolts but they are correct.
It almost sounds like its coming from the front and back; but manily the back where it is occasionally "pinging". I have heard many other LC do this but mine was always tight. A new gremlin to chase-
