Attn: ALL SURFERS
Hey guys sorry to start a new thread. I did search... but I was wondering how people carry their boards on say a full length basket. Even a half basket. I kayak too so any pics or info on conversion style bars would be much appreciated. I've been wanting to remove this God awful rust inhibiting POS but haven't had the time or money, on my list though. Also any beach cruiser porn would be nice.
I have a megawarrior yakima basket w/ext. I just used the aux cross poles and some pipe insulation/foam around them with a couple zip ties then just tied the boards down. I dont have any kayaks, but the bars are the standard size for yak and any of the their attachements will fit. HTH.
EDIT: Just re-read what you said. So you have the stock racks currently and no rack? or looking for a cheap rack replacement after the stock is gone? All the same the pipe insulation has always worked well, just find the right dia stuff for the size of cross member you'll be running.
Yes, I have the stock racks but have nightmares about their 50 pound weight limit. I am not opposed to buying a nice (African Outback) if it will fit my needs just curious what others are doing. And Thank You for the quick response!
Cool. The Baja racks look pretty sweet. I wouldn't worry to much on attaching your stuff. Sorry I dont have any pics of mine loaded up.
another yak attack here. no factory rack ever so I dodged that bullet:D
Yeh it just scares me to put a thousand dollars in something then not have it suit me perfectly, or atleast be able to adapt it. The baja racks are nice but all manufacturers of racks are pretty much a thousand dollars. Then full length or half. Half would be easier with boards but the kayak becomes another question.
I was out in it last friday. can't believe I forgot the camera:doh:
next time you swing north I'll tell you where;)
The "real" deal racks are spendy for sure. But Im into a pretty slick setup for maybe $600. The yak stuff isnt quite as built and sturdy as more $$ ones, but it works great for my needs. Bikes, Skis, Boards, camping gear.
Most parts are easily found used at a fraction of cost.
The Yakima's and thules are not as cool as the expedition racks but are nonetheless quite functional for kayaks and bikes. They are also easily removed before you hit the trail lest you scrape them off. Here are some piks of mine. the front fairing cuts down on wind noise enough that you can still use the sunroof. IH8MUD Forums - View Single Post - ROTW douglashuft
Any guys carrying boards on the full length baskets, like ARB, INTI, Con-fer, or African Outback. I really dig the sunroof hatch. As well as the idea of being able to get up on the roof and sit in a chair, kinda :hillbilly: I know but hey:beer:.
You'd have to fab a floor to use the fullsize ARB style racks as a platform for a chair. And you'd have to fab or adapt crossbars with pads to hold boards/boats. A fullsize rack is pretty long - so if you have shortboards maybe they would fit inside, but longboards would need to be supported above the rack lip.
For boards, bikes and yaks its hard to beat a yak/thule. Ebay has 'em cheap - buy the towers used, and get new crossbars locally. They work in addition to the factory rack, no need to remove it.
If you want a upper deck to sit/sleep/hang out on, run three or 4 crossbars and lay down a piece of 1/2 plywood: instant rooftop deck. Helps keep the inside cool as well, sort of like always being parked in the shade.
For kayaks it is best to mix and match. If you use the Yakima hully rollers on the rear then you want to use square thule crossbars so the hully rollers dont rotate out of position where they are clamped. The thule cradles work well on the front because they have felt on them so the boat slides better than with the yakima cradles.
The BajaRacks are far less than $1000. In fact, they've offered a MUD discount. See here for more details: https://forum.ih8mud.com/80-series-tech/262586-new-roof-rack-80-series-made-baja-racks-awesome.html
For now, you'll have to source your own yak or board attachments, but it shouldn't be too difficult to figure out how to attach them.
SnT'07
Should have brought the booties... especially after just getting back from surfing in Hawaii with no need for a wetsuit.
LC 4 Surf
Here are a few pics of my set up. Yakima cross bars. In older photo (fully loaded one) I had a basket in between the surf boards and the bike (look closely you can see the red bungie net). More recently I added the loadwarrior. With long enough bars (I think they are 66") I am able to fit my wide longboard and the full size cage. In the winter, I just slide the cage to the center (2 minute adjustment).
