DirtDauberGarage
- Year
- 1997
- Vehicle Model
- 80 Series
- Location
- Peachtree Corners, Georgia 30092 United States
- Mileage
- 275000
- Color
- silver
1997 Toyota FZJ80 Land Cruiser – TRIPLE LOCKED - $16,500
This 80 has been VERY well taken care of and owned by another MUD member and me since 2007.
Clean CarFax with no accidents. All VIN numbers on body panels match.
All glass is original Toyota except the windshield
All services and maintenance are done with OEM Toyota parts.
The dash is perfect (no cracks).
All the LOCKERS work
Never overheated.
Desert Dune / Moonglow
275,000 miles
The Good (Most of this was done by the previous owner)
Never overheated.
275,000 miles
- Always maintained with OEM Toyota parts.
- All heater hoses replaced (including the pesky hose)
- Southern Truck NO RUST underneath (See pics)
- Ice cold AC (Newer Compressor)
- “Slee Offroad” light harness
- Dobinson suspension in 2018. Progressive coil springs, caster correction bushings, steering damper, and shocks (C59-220V, C59-269V, G559-683, G559-682, SD59-824). It rides GREAT!
- Front Axle completely rebuilt with all new seals and Koyo bearings in 2019 (Low mileage since)
- Both of the front spindles were new from Cruiser Outfiters in 2019. Only driven a few miles since then
- New spedo gear to fix MPH for 285 tires
- 2nd Battery box from Cruiser Dan
- Washer Fluid relocator
- New Plugs, Wires, Cap, Rotor
- Distributor O ring seal
- Fuel Filter
- PCV and PCV hoses
- Valve Cover Gasket
- Front Oil pump seal
- Replaced Phillips-style screws on the oil pump cover with stainless steel Torx and hex head bolts when reassembling to prevent future issues.
- Front Crank Seal
- Belts
- Thermostat and Water pump
- Air Filter
- ScanGauge
- Radiator
- ARB Bumper
- Hanna Quality Rock Sliders
- OEM Fog Light switch (Not hooked up)
- Center Diff Switch
- Heat shield wrap around the engine harness by the EGR
- ABS Delete
- Brand New AISIN Clutch fan
- Brand New Golanders MT 285/75/17 (Less than 2000 miles)
- New FJ Cruiser 17-inch wheels
- I have the original rims
- Tons of other EXTRA parts (Radiator, Distributor cap, Fan Clutch, Oil Filters, New seat cushion, etc.). Too many to list.
- I do have the third row seats.
- Husky Floor and rear cargo liners
- Front seats need to be recovered. They are not bad, but they have the usual 30-year-old Toyota leather cracks.
- Flood lights need to be hooked up to the dash switch
- Both front seats work intermittently. I got them where they are comfortable and just don’t touch them
- Rust spot on the rear hatch
- Hood, Roof, and fender flares need clear coat to be repainted
