at the buzzer ?
chichester nh
hey all , got a 2003 4 runner limited , 8 cly. 175 miles, the other day I started it, abs light is on and a buzzer is buzzing , finally fades away, repeat on second start, fluid level is good, breaks are squishy then pump up fine. is this a possible master cylinder fail ? THANKS
That is exactly what it is doing. That is the warning for loss of pressure and imminent total brake failure. Usually the motor and accumulator. If you can find a rebuilt motor/accumulator online you can swap those pieces onto your MC to save you around $1900.
THANKS VLAD, IM ALL FOR SAVING 2G. NOW TO FIND SAID MOTOR AND ACCUMULATOR????? ANY IDEAS , YOU SEEM TO BE A GURU ON THESE BEASTS . THANKS AGAIN.
