Assumed stock distributor - still good?
Tucson, AZ
I have what I assume to be the stock distrobutor in my '68. I was having some carburetor issues (Rochester 2 jet) and the guy inspected the distributor and deemed it bad - worn bushings.
I also inspected the dist. and I can feel play up and down, but none side to side. Here's a link to the video I took.
I apologize for the poor cinematography but it's the best I could do under the circumstances.
What do you think - is the dist. bad? If so, can I rebuild it or do I need a new one? Aftermarket or OEM?
Thanks for confirming my suspicions. I'll get a cap and rotor and call it a day (already got new wires).
I did rebuild the carb and couldn't get it to run correctly - lots of sputtering and hesitation on acceleration. Turns out I had the mix screws too far out AND there's a stripped bolt on the manifold that was letting in a bit of excess air.
I got a helicoil kit and will address that stripped hole this weekend.
My 72 came to me in 82 with a Delco distributor and a Rochester 2BBL. I "rebuilt" the dizzy early 2000's. I had to take the top of the carb off to free the accelerator leather pump cup - had like a blob of glue bonding the pump cup. Last year the dizzy had a ton of slop. So I bought the chinesium amoron one and swapped it. Ran great for like a week - the points arm bent - put in the points and capacitor from old Delco. I like the straight mechanical advance. Only vacuum thing on my rig is the vacuum gauge. Has been running great. Need to clean the carb - bought a heated ultrasonic cleaner with a gallon of carb juice for the task. Getting about 17/18 mpg now, back in the day it was 25mpg.
You are a better man than me if you can measure thousands with fingers. Points are quite specific on adjustment , example .018, so a few .001s can make a difference. A measuring tool is needed in this area. There is reason for going electronic in this area.
That is a fine dizzy. They can be re-bushed, though I've not done it. I ran one with a Pertronix for many trouble free years. I like the octane adjuster for quick fine-tuning of the timing and the little brass oiler cup is just cool. Clean it up and run it.
The reason you had success with pertornix is exactly what i said. The pertronix is ELECTRONIC. Instead of a cam opening and closing points to .018 800 times a minute, or more , it breaks a magnetic field the same. As the distributer wears out , a magnetic field is very tolerant of mechanical ware. You are basically telling one to go electronic as you had many trouble free years wihtout using points. I agree.
