armor = wobble?
North Cadillac
Trying to figure out what the heck is the deal. I just re-installed my ARB (after getting a fresh powdercoat on it) with the T-max 12,500 winch, along with the IPOR rear bumper with tire carrier and jerry can swing outs. With the truck empty it sat pretty high but rode smooth.
Now with the weight on it there is a wobble like the tires are out of balance. I have checked the front and rear wheel bearings for play and they are tight. I recently added additional innovative tire balance beads to the tires thinking this would smooth them out and it did, some.
Should i just keep adding more beads? It honestly does feel like a tire is out of balance--wobble in the steering wheel, change shaking in the change holders, and it gets worse as i go from 60 mph to 65 or 70 mph.
I'm a bit puzzled why it would ride smooth with no weight and wobbly with weight?
Keep in mind that dyna beads or the likes DO NOT solve lateral imbalance. With a wider tire there will be a greater chance for lateral imbalance.
As for your problem, could the hight change be enough to cuase a change in u-joint angles?
I'm very sure it's not ujoints. It's not a grrrr, it's a wobble felt through the truck.
Worn out/blown shocks?
i'm thinking that perhaps it's a worn bushing in the panhard, since it still has the original bushing. And, i have a slight death wobble....so worn bushing plus death wobble equals this shaking i'm getting.
What do you think?
BHMCruiser, i see what you are saying. I will get a sweep and see where its at since i'm curious anyways.
I second the castor angle idea. Adding that much weight could change the caster angle and that much extra weight could intensify a problem that was already there with the worn bushings.
You need to get an alignment before anything else since you've basically changed your lift.
A bit of death wobble and the other stuff sounds like toe to me. It doesn't take much even without the extra weight.
...thread revival...
CJ,
did replacing the panhard bushing correct the wobble? if not, what did?
i never ended up replacing the panhard bushings. I'm sure they need it, but basically getting my caster back close to spec fixed it. And making sure my tires were balanced.
