Arizona Classifieds / For Sale / Wanted
@medtro aren't the lower control arms for the 80 and the 100 the same? It would seem so based on Slee site. @D_Web was looking for lower control arms.
I believe they have the same length. The hole on the 80 bushing and bolt are bigger. The mount bracket holes on the 100 series will need to be enlarged for this to work. This is from reading on the internet, I haven't verified it myself.
3 - 315/75/16 Pro Comp Extreme Mud Terrains. 50% plus tread left. A little chunking. $125 each or $350 for the set.
I will also be at the meet Friday if you want to pick them up there.
Thanks for the additional info. I'm going to go with something heavier than stock to (hopefully) avoid it happening again.
It would be easier to use the 100 bolts with a sleeve to make up the difference when using larger 80 series bushings. This is what slee does FWIW.
Interested in the rear bumper, unless it is a bolt on style.
They unit does bolt on but I don’t see why you couldn’t weld too if that was your preference
