ARB Intensity Solis
Did you get these installed? Soon after I asked about them I bought a set and mounted them on my 200 series. Mounted up really easy.
installed another set on my 1994 80 series this morning. I can't get them to work. Instructions say to modify the harness and get a relay if your vehicle is negatively switched. I understand the 80 is negatively switched? Curious if anyone that has installed these successfully on on 80 has any pointers.
Negatively switched is a common term, but kinda confusing because folks that understand electronics know that the switch for a device can be on either the positive or negative wire. But, what if the device is bolted to the chassis (or structure that's grounded) and uses that for the ground or "negative" connection? Then there's no place to "negatively switch" that device. IMHO, "negatively switched" just means that the device isn't grounded by the mounting bolts/screws, but has a negative wire that needs to be grounded. If you're having an issue that these lights don't work, check your connections with a voltmeter to verify that you're getting the 12V to the lights when you need them. Also, some 12V sources are constant and others are only when the ignition is on or engine is running. Pick the one you want.
Haven't installed them, yet.
But will take note on the issue you mention.
Cheers
