ARB Front Lockers vrs. Atrac ?
here is a perfect link from 80's tech faq. It will tell you all about lockers
https://forum.ih8mud.com/showpost.php?p=1012338&postcount=4
Think of ATRAC as completely independent system. It uses your ABS brake sensors to detect differential wheelspin. If you are locked, both wheels spin at the same rate= no differential wheelspin, thus ATRAC will not engage.
ARB's will not interfere or conflict w/ the ATRAC.
I re-read your orig post. I guess I didnt answer your question tho, hehe.
ATRAC is not a locker, it is basically a LSD using your brakes just as they would if you slammed on the brake pedal. It pulses the brakes so you maintain traction- it just activates on the go pedal instead of brake. Very ingenious and brilliantly simple.
However, it doesn't "lock" the diff so you will still slip.
FirstToy said:
SurfPonto, more than a few of those occured w/o the locker turned on. Still a big ? as to what is going on w/ the OEM locked rr diff...
Guess I should have read it more closely. Hopefully if it is a common issue Toyota will step up to the plate and take care of it.
Currently the A-trac is turned off when you engage the rear locker. The future holds that the front will stay turned on when the rear locker is engaged. Just like the pre-production one that wheeled the Rubicon last year. So locked rear, simulated LSD in the front. later robbie
FWIW I have driven locked trucks for years and the FJC with just the ATRAC (no lockers engaged at all) and could go places I would wander side to side with the locker.
I would run ATRAC all day on the trail and never touch the locker button unless there was a specific line that warranted it.
I agree with Dan, the ATRAC is an awesome feature. I have been using it with my Land Rover (LRs is called electronic traction control - etc) for several years now and it is very impressive. There are only certain situations where I would see a locker being the advantage.
