ARB Bumper / Suspension advice
Washington, D.C.
Good morning all:
A little background:
This weekend I took the ARB bullbar w/12k winch off of my '94 and put it on my '97. The '94 had OME heavies in the front and mediums in the rear. The '97 has mediums front and rear. I'm selling the '94.
Two things:
1. If you plan on putting an ARB on yourself, don't. It's a huge pain in the ass. It helps a lot to have someone help lift.
2. Should I switch out the Mediums and Heavies in the front of the two cruisers, or just run spacers on the new truck? I know it's the same spring rate, but I need to get my nose off the ground. Anyone running the 20mm difference in spacers? What do you think? The Mediums have about 20k miles on them; the Heavies have about 40k miles on them, but are in good shape.
I look forward to your feedback.
Jay
I'd swap springs.
I'll help you swap springs, especially if you would consider selling me the mediums ;) . would adding a spacer be easier than swapping springs?
I appreciate the offer, but I've got to sell the '94, so it either has to keep the Heavies or the swapped Mediums. If I sold the Mediums to you, the '94 would have no springs. That's a tough sell, even in Mountain Brook.
I don't know that adding a spacer would be easier than putting spring into one truck, but swapping springs is twice the labor.
plus you'd need jack stands and floor jacks for both trucks, I didn't think of that - my original thought was that you could use the springs from my 92 to put your 94 back to stock, but I think you are right on the labor involved and can probably do better selling yours with the lift.
How does it sit with the heavies up front without the arb and winch?
I like how it looks. No stink-bug; it sits very even. It also rides pretty well, too.
A possible solution would be to do all three trucks, leaving the '94 as stock, but then you'd also need the castor correcting bushings, or we'd have to trade out control arms. It could get pretty complicated pretty quickly.
here's one reason to swap: If you put the heavies in, and in the future you want to put spacers in front and rear to add a little lift you can use spacers. If you keep the mediums you are probably all "spacered out". :)
As long as your shock hardware isn't all rusted out it's an easy swap, some of the spacers will crush overtime and they cost money. So if it were my rig, I would swap them and have the better setup in the one your keeping.
I have 851s in front plus 1.5" of metal (!) spacers. With ARB and M12000 it sits at 22" so 2" over OEM.
Spring rate of 851 and 850 is the same as you said. Of course, you have a bit more "compression room" on the latter. Not a biggie in my book since how often do you fully compress a spring anyway with the bumpstops in the way etc. Only slightly more work to put metal spacer on than swap spring. Spacer more versatile cuz you can use them with other springs plus easier to sell and cheaper to ship. I would not go rubber spacer. Metal best but costlier. Poly reasonable compromise.
