ARB Air Locker question:
Tucson, AZ
One of my Cruisers (don't ask which one :D) is having an AIR front locker issue. Here's the details:
*The front locker will lock though the compressor keeps cycling
*Inside the bay by the front locker solenoid you can feel hear and feel air blowing out from the solenoid. I tried to finger-tighten the nut though it's tight.
*If you keep using the locker I find some gear oil spray in the bay (not much though).
One guy told me that if you see gear oil spray then the trouble is down in the pumpkin. I am doubting this for my issue because I see and hear a leak at the solenoid.
Thoughts?
If the leak is coming through the exhaust port in the solenoid then the solenoid sounds shot to me. It's possible that the valve is stuck. You could try a light tap tap tap while that locker is engaged and see if it frees up. Or just replace it. They are pricey from ARB, but I think someone sourced a direct replacement from another vendor. You'll need to search for that.
Solenoid part# 180103 $60.02
Thoughts?
Shotts...
I think the "guy" is correct. Chris Wood gave a presentation to Rising Sun Club awhile back and I know this was specifically mentioned. Something to do with the seal down in the diff that allows air, and if the leak is bad enough, gear oil, to be forced back up the air line to the solenoid. Sorry not more definitive help but I betcha ARB tech support could tell you exactly what the problem is :D
the air lockers can leak oil into the air line if not installed correctly, or being to rough and not lubing o rings correctly when assembling.
If the solonoid is leaking air though, it sounds like it is the issue.
Try disconnecting both ends of the line, blow it clear, and wash out the solonoid, see if it comes good.
Thanks everyone. I'll start with cleaning that solenoid. If that's not the culprit I'll go from there. Thanks! J
Everyone is correct
I just dealt with the same symptoms on my FJ40. It was a combination of both the leaking o-rings at the locker and a stuck solenoid.
As corsair and ats4x4 mentioned a leak at the o-rings of the locker can pressurize the axle housing and force oil back up the air line. Oil then gets into the compressor tank and up to the solenoid valves. The solenoid valve gets gummed up with oil and sticks open and you see oil blow-by through the exhaust port.
In addition to R&Ring the solenoid I suggest you open the compressor tank and check the air lines for oil. Repairing or replacing the solenoid may solve your problem for a short time, but if you continue to get oil build up through the air lines, the problem will most likely return. The oil blow-by that you mentioned is a strong indication that oil is travelling up from the diff.
sometimes,a s I mentioned earlier, blowing out the line clean can prevent the vacuum effect that sucks more oil into the line, when it tries to push whats in the line out, can fix it long term *sometimes* but doesnt fix the cause.
