Aqualu cowl issues...need to brainstorm
2/79 FJ40...swapping items from OEM steel cowl over to Aqualu cowl/tub
Questions concern the carb fan cooler and the blower fan...
Each unit is postioned either side of the cowl with air intake to each blower coming thru the cowl vents. In the pictures note that Mr. Toyota actually had built a small ductway from the cowl vents to the inlets of the respective devices. See attached images...
On the Aqualu cowl there is no such "duct work", and my carb fan cooler or blower fan does not butt-up against the inside of the cowl vents. Hence inlet air, will be from the engine compartment.
(1) Should I be concerned?
(2) Try to take the OEM ductwork and fit it to the Aqualu?
(3) Open to any other workarounds people have done...
Thanks, let me hear your ideas!
Cheers,
Dave
needs more pictures or a drawing!
O.K. more pictures tomorrow...come on you Aqualu converts!!
The top picture is from the inside of the OEM cowl looking out thru the louvers of the drivers side. Normally there would be a carb cooling fan bolted up to that square box (note bolt holding hardline...two attachments for the carb fan inlet are also right there along the top of the box)
Bottom pix is of the passenger side louver as seen from inside the engine compartment. This is where the fan inlet for the fresh/heated air blower would be. The blower is bolted to the firewall of the cowl, and the inlet of the blower is simply sealed with foam and "butted up" again the metal "ductwork" box opening to the louvers.
Dave
Problem resolved...
Cut the spot welds holding "ductwork" in place. Placed and fitted on Aqualu cowl
Holes drilled, just need to countersink and buck the rivets. Pictures this weekend?
Dave
How about...
Cutting the opening such that you can bend tabs inward to allow for the removeable vents on the older models to bolt upto?
