AOE bumper group buy???
Hey that's my LX ! I thought that truck looked awesomely familiar :)
I've had the bumper from the time Alex was finalizing his design and at the same time had him customize a rear 4x4labs with double swing outs and sliders with custom higher cat protection since they got turned up.
I love the bumper.
AOE industries 80's Front Bumper
This bumper was uniquely created to fill a void . It was designed to answer the needs of an experienced group of customers. The 80 series front bumper has high clearance to go over huge boulders, and it has been tested on the California Mountains and deserts. A perfect combination of weight and strength makes this bumper unstoppable.
Features:
-Manufactured from 3/16 cold rolled steel
-High Clearance
-D-ring mounts made of 3/4 Steel
-Fog light mounting
-Winch Mount design to work with WARN 9.5 CTI, XP series, VR10000
-Additional Light Mounting Point
-Integrated Hi-Lift Recovery Point
-Black Textured Powder coating
-Built in Skid Plate
-Single 12 Volts marine grade adapter
*Fairlead NOT Included*
-Weight: 116 lbs , 53 KG.
That looks pretty good in black. Not a big fan of the bare steel look...
Can you get it without the big AOE in front? Not a fan of that either.
What would the 12v outlet be used for?
You can get it without the AOE cut out but he charge more for some reason, I figure it would cost less...
I love the bumper.
Yup it is. Hope you don't mined. It looks awesome on your rig.
I'm going to visit Alex's shop in a few hours, i will be paying for the first set of bumpers so he can start work.
Excellent!!!
Wrench, great pics and thanks for posting the bumper specs :) Looks like you won't have to be angry after all.
No Problem! Thanks. I'm just anxious to get it.
Not at all, I painted the front part of the fender just under the bumper flat black so it looks even cleaner. They can also be cut out.
Are we left to figure out what to do if we want turn signals, or does Alex have a pre-designed solution? I see a couple photos in which custom round turn signals appears to be integrated.
Lots of options, the easiest being to make your side marker the turn signal.
Ammo
I simply switched the corner marker light bulb sockets with the turn signal ones. Just turn/pull and switch them, no tools or cutting needed. I also like the led strips some of the customers have used in the groove under the headlights.
That's what I plan on doing.
More money sent to add the fog light cut-outs to my bumper - thanks Socallove for all the leg work and hats off to Alex and all the people over at AOE for this group buy. Can hardly wait for my early X-mas present to get here.
This is exactly what I was going to do as well. :cheers:
Does anyone have the actual winch pocket DIA? I know I'll have some fab and cutting regardless... It looks like the pocket is full frame width, depth and height to top plate would be awesome! ;-)
My application. Is not exactly standard, so knowing the baseline helps to understand just how much fab I have ahead.
Thanks,
-A
