Pour the gear oil in till it was flowing out the fill hole(meaning full), then quickly screwed in the bolt.
I see, I will unscrew the bolt and let it flow out till it stops then.
Some confusion here: when i filled the front axle, I unscrewed the 6 point bolt in the middle of the axle(the one I rounded trying to get off the first time, then had to take it in), on the front. Just above the drain bolt if you will. Not sure what your refering to about square plug. I never messed with that..
Oh, your talking about the plug to fill the birfiled with grease. (had to look it up). Ok, so now I can add grease to the burfield since I am sure the previously leaking axle, all the SOUP leaked out.
