Shopping for wheels and tires and these could fit the bill but would love to see pics of them on a 200. TIA
SCS SR8 wheels 18x9
From SCS on another thread:
"Even if you take in account the GAWR, you'll exceed that load before maxing out the wheel's load rating. Even at 2200lbs, there's also a safety margin that's not accounted for in the rating.
This model was developed to cater towards the 2nd and 3rd gen Tundra hence the reason why we choose this specific load rating. Other wheel companies create one mold and uses that same mold to offer wheels in different bolt pattern to suit midsize and fullsize trucks. For instance, there are a lot of Tacoma trucks out there that run wheels with a load rating of 2500-3000lbs, this is overkill. You're just adding unnecessary unsprung weight. A lighter set of wheels/tires can help in braking and acceleration especially if you're going from super heavy steel wheels to alloy wheels."
You can't argue with that! Thanks for the info. This forum continues toThere's a lot wrong with this quote.
Let's start with a quote from the Year Book of the Tire and Rim Association, Inc. (The Tire and Rim Association, Inc.) whose purposes include the establishment and promulgation of interchangeability standards for tires, rims and allied parts for the guidance of manufacturers of motor vehicles, aircraft and other wheeled vehicles and equipment, and governmental and other regulatory bodies:
RIM AND WHEEL LOAD AND INFLATION INFORMATION
IMPORTANT - Rim dimensions are standardized by The Tire and Rim Association for size and contour only, and particular tire and rim combinations are designated to assure proper mounting and fit of the tire to the rim. The load and cold inflation pressure imposed on the rim and wheel must not exceed the rim and wheel manufacturer's recommendations even though the tire may be approved for a higher load or inflation.
In the case of a LC200, the "load and cold inflation pressure imposed on the rim and wheel" is 2,512 pounds and 33psi for the stock P285/60R18 tires. This exceeds the 2,200 pound Max Load specified by SCS. This is not acceptable.
The rear GAWR on an LC200 is 4,300 pounds:
Generally, the GAWR should not exceed 87% of the combined Load Limit of the tire/wheel combination on that axle leaving a Safety Margin of 13%. In the case of our rear axles, this means that 4,300 pounds should not exceed 87% of 2,512 pounds times 2 = 5,024 pounds, and it does not (4300 / (2*2512) = 85.6%) which leaves a Safety Margin of 14.4%.
However, if the wheels are limited to 2,200 pounds, then the calculation becomes 4300/(2*2200) = 97.7% and results in an unsafe safety margin of only 2.3%.
To me, it is clear that the SCS wheels under discussion are not suitable for use on a LC200.
HTH
tl; dr - we should be using 2755# as the factory wheel rating, not 2512#.
The Lowell's Australian GVM upgrade increases the GVWR from 3300kg to 3800kg with only suspension upgrades (Update - Lovells GVM Upgrade for Landcruiser 200 Series - RVeeThereYet.com). That increases the per-axle capacity as shown below. Note that in their tire loading info it shows an increased maximum tire load of 1250kg (2755#). Since the GVM upgrade is approved by the Australian government, I would think that the factory wheels are good to at least 2755#, otherwise new wheels would have been included.
By the calculation that @gaijin shows above, that's 2000kg / (2*1250kg) = 80%, which is a 20% margin of safety.
OK, there's a lot of good info here, but it looks like we might have some confusion about the terms being used.
A "Maximum Load Rating" is not the same as a "Load Limit." My calcs (and the standards) are based on Load Limit which is the mass a tire can safely support at the specified Cold Tire Inflation Pressure.
...the data imply that Toyota was allowing some "safety margin" in the GAWR such that the rear could be loaded up to a limit and the front could be loaded up to a limit, but one could not load both up to their limits...
If you want to use 2598 pounds as a minimum Load Rating for a wheel instead of 2512 pounds, that's great ... as far as it goes. But (and this is a big "But") I think we should be using some number GREATER than the maximum expected tire Load Limit as an acceptable Load Rating for any wheel. I don't know what this number should be, but if we expect a tire Load Limit of 2598 pounds in practice, then I would expect that a wheel Load Rating should be 2598 plus some safety margin.
My guess is between 6-8k lbs, stock-built.What wheel rating do we need ideally? I'm in contact with American Eagle and told them what we're doing with our rigs and they requested an ideal weight rating.....
What is the 200 weight approx. with gear, bumpers etc?
It sounds like most of the concern is focused on maintaining safety margin over the listed values, which I'm assuming already contain some safety margin. If a wheel has a max load rating of 2,200 lbs and a stock 200 is roughly 6k lbs, the wheels should generally work, no? Or are we assuming no margin and a scenario where one wheel is loaded much more than the others? And why are so many people able to run wheels with similar ratings on their 4runners, Tundras, and 100s with no known defects?
The math is tellin me no but my eyes are tellin me yes...
No. Bone stock tires are required to support 2,512 pounds. Any wheel must be rated for AT LEAST that much. That's with absolutely ZERO "safety margin."
Honestly, if you have read my previous posts in this thread and still believe that a wheel with a Load Rating of 2200 pounds is good to go on a LC200 ... I don't know what more I can say.
It's your rig, of course. You are free to run whatever wheel/tire combination you desire.
HTH
I read it and that's why I said that math makes me question certain wheels but i'm baffled as to why so many people are able to run the setups that they do without incident.
