Anyone mount ARB 2500 Awning to stock roof rack?
It's so awesome how a rectangular aluminum plate with a few holes drilled into it is the best solution and also one of the cheapest!
With the money I saved on fancy brackets I can buy the side wall to go with my awning!
agreed! while Camping this past weekend a guy was asking me about the setup. I happily share the solution from mud.
Not an Ironman awning, but these are the mounts I threw together.
Thank you to everyone posting pics and ideas on this thread!
I purchased the Yakima T bolt with nut kit that slides perfectly in the factory roof rack channel
https://www.etrailer.com/Accessories-and-Parts/Yakima/Y8880184.html
I also purchased 1/4" flat aluminum bar stock from Grainger 4" x 12" (and cut it in half to have 2 4x6" mounts, one front and one back)
I used the Ironman quick release awning mount
Great install and thanks for the pics. I will also be installing an ARB 2500 on my rig and trying to overcome some challenges. I have a roof basket installed on the roof that I wish to keep intact, did buy the L-brackets and will somehow see how I can work around that. will post pics later.
Since my LC has a roof basket that I wanted to keep, I found two installation points where I can secure and bolt on a couple of L-brackets using new, longer hardware. I spaced out the L-brackets so there will be support on the rear and middle section. After positioning the awning with the supplied T-bolts (?) and tightening them, the awning seems pretty solid.
For good measure, I wanted to support the front section as well. I elected to buy a gutter-mounted cross bar where I can rig up an installation point. For future, I can use the cross bar as well to mount an LED light bar. Below is how I did it.
