Anyone know about this?
there are a couple current threads discussing the option.
Landcruisinmy93 is working on a kit so to speak and nearing completion
I hate that a couple of months after I started collecting parts this was released. Ruined the "being the first" but I will be the first with a manual lol. Whatever makes us feel better.
I actually took final measurements last night for the final piece and realized my original design won't work at the current adapter plate thickness. So, I will either have to have a custom aluminum flywheel with replaceable steel face made or go a little thicker on the adapter plate. Either way it will cost me about the same to remedy. A custom flywheel would mean fewer parts and could be rebuilt, but the current flywheel choice can be picked up from a parts store just about anywhere... even though most parts stores order things like that anymore. Even if I double the adapter thickness it's not going to make a real difference anywhere else as the engine is so much smaller than the 1fz-fe.
Sweet I will be eagerly waiting to see your results.
What is the opinion on advantages of installing this engine over swapping in a Toyota 1HD-T?
(since the 1HD-T has many options for off the shelf OEM Toyota parts to facilitate a swap).
Options are always advantageous, especially with advantages included.
Would like to hear about savings in cost, more efficiency, ease of getting engine and or repair parts etc.
Thanks.
Realistically there isn't much if any that I can factually quote because I'm not super familiar with the 1h(x) motors. I can only tell you that it was available in the states and I bought my OM606 for $1400 delivered to my door from Pennsylvania, it has been rebuilt at some point in its 149k mile life, likely due to the PO obviously running straight Veg oil through the electronic injection pump.
The OM606 is cheap and easy to convert to a fully mechanical injection system which makes it electronically simple like the Cummins install.
If 170hp and 250lb-ft torque isn't enough for you, a few simple adjustments to the stock mechanical pump and boost pressure and you get stock land cruiser numbers. You can get injection pumps built for fairly cheap by DieselPumpsUk, Myna Diesel or DieselMeken. I have a 400hp capable DieselMeken pump. $1300 to my door. Adding an HX35W in compound for next to no lag $450 for used Cummins turbo, rebuild kit and all necessary plumbing. There are other parts which will make installation easier. Like the oil pump and pan for a rear sump. Add another $500 for a used pump and new pan. Another $120 if you want the Anti-noise capsule for even quieter running.
The engine on a full sized oak pallet on a tire with a giant bad battery was 545 lbs. so the engine is smaller than the 1fz-fe dimensionally and much lighter.
DieselPumpsUk who I purchased my pump through, who subs some work to DieselMeken who actually made my pump get at least 24 mpg fairly easily with an automatic making 500hp pulling an 80's Ford F-250. So I'm guessing that you may get slightly better or at least equal results making less HP with a manual transmission. Only time and testing will tell.
The transmission I'm designing the adapter for is the R150f used behind Toyota trucks and 4runners from 1995 to 2002. The transmissions are cheap and the parts to adapt a split case aren't terrible. The one upside is that once you've purchased the necessary parts to run a split case you just swap them over if you ever replace the transmission. The R-series has been known to survive behind 500hp supras with minimal upgrades. Marlin makes a thrust washer and bearing retainer plate which allow this...less than $200 in upgrades. You can swap your first and 5th gears with other R-series transmissions if you'd like different gearing also. The R-150f weighs a lot less than the a442f also.
The OM606 is built over square, so it doesn't drive like most diesels. It revs into the 5k rpm range with ease and is limited there at the factory, but with built IP you can take it to 7k rpm no problem. For the most part it drives like a gasser So theoretically it shouldn't change the driving experience all that much...unless you have some additional power and a manual and part time case. One thing is the it doesn't make gobs more torque than HP like a Cummins, which I think the diffs will appreciate. I can't attest to the 1h(x) motors because I don't know how those perform.
The original plan was to swap it for under $7k but I've been getting a little carried away with unnecessary things like having transmission cases and stuff cleaned. And the costs associated with adapter development. But it should still come out close. So far it looks like I may go over by $1.5k but I originally didn't didn't plan on more power which cost more money in parts, I also didn't plan on doing a manual trans and part time case. Or rebuilding the transfer case...not worried about transmission it costs
More for a rebuild kit than to get another unit. And I didn't plan on farming out parts cleaning or buying upgrades alternator etc... honestly, if I had gone with my original plan, cost of parts and doing all my own labor I could probably have done it for <$5.5k including all the maintenance parts I replaced.
So to summarize. It can be done cheaper than a Cummins if you don't want gobs of unnecessary power, even cheaper if you were to just keep the Automatic and full time transfer. And cheaper if you didn't farm out parts cleaning. If you have fabrication skills and want a diesel that gets great fuel economy and is basically equally as powerful as the 1fz-fe then a swap can be done for around $5-7k. Diesel Adapters kit...albeit much more comprehensive than a basic adapter is $5k and even with all the goodies it's hard to find an entire 1h(x) swap for the same cost.
Whew! Tapping all his out on a glitchy iPhone was a task lol. Anyway, I hope this little bit sheds some light on the thought process.
I really like what you're doing here. What year merc is your 606 out of? I'll be moving back to SoCal soon and I want to bring my trucks with me.
Mine comes from a 1999 e300 turbodiesel. I'm not sure how the emissions registration will work in California, but often I see the 80 series listed on Toyota parts sites as the a station wagon body style, not sure if that holds up at the DMV as being applicable, but the OM606 was offered in different forms in different years and in Station wagons also. Maybe it will make it easier to register? Probably not, but maybe. Also the oil pan and pump are off an OM648 which did come in an SUV/ station wagon, so if you are shady...and I'm not condoning it, you could point out the serial numbers on the pan and say it's an om648 from an E320 lol. But I in no way condone falsification of government documents for any reason. I'm just pointing out if someone were desperate and shady they might get away with it if they couldn't register it the other way.
Edit: seeing as I seem to be repeating myself on some things and there seems to be some interest. There are some pics of the rudimentary adapter plate and engine on my build thread page as well as some more info.
My 3 linked daily driver build thread
Keep in mind that the bulky square plate is the first iteration of the adapter plate so I didn't want to waist money and time making it a final product until I knew all of my measurements were correct and everything lined up properly. The final plate will be machined to shape.
