Anyone have Orange Box Fab window storage
Looks like they might slightly interfere with the mounting of our brackets. Our brackets match the angle of the sheetmetal under the handle, from the above pics it looks like the mount under the handle is going down at a little more of a vertical angle. Something that will for sure work with our brackets is this: Delta Vehicle Systems ceiling storage options (if you already have our brackets)
Thanks for that! Current I have your brackets, a Speski barrier and a new (to me) Orange Boxx PSD. I’m trying to make it all fit (well enough). This is my current setup.
Ah! Very cool. Looking forward to the results, please post up. It's always nice to know our products "play well with others"!
It came together nicely I think.
I bought the Speski barrier used from a member on here and it had already been modified to grab the rear seat belt top bolt which I think would be imperative to this install. Also, not sure if it is original to the Speski install kit but there are pacers between the @Delta VS brakets and the @NLXTACY Speski barrier. The @orangeboxxfab PSD panel is touching the headliner where it bolts into the now deleted grab handles. I even managed to get the PSD and the barrier to share a bolt which really locks all this together.
I’m sure it’s overloaded but there are now 3 different vendors bolted in, quite securely I might add, to the deleted passenger side 3rd grab handle.
Glad that everything worked so well together based on, what seems to be, a first attempt.
I’m ready for some nighttime COVID mall cruising now!
Very cool, thanks a LOT for the details and pics. Much appreciated.
Edit: the lights on the sides are from @Sloop Imports. They are awesome. They’re magnetic and switched for red and / or white on the actual light itself. They can be moved such that the can provide direct light (pictured) or flipped around the side of the @Delta VS brackets to offer more indirect lighting. This indirect, or mood lighting as I prefer to call it, really gets the soccer moms at the mall super randy. No need to install a switch for these. I just ran power up through the trim piece on D pillar. With the attic storage, the cargo dome light is often covered up and I needed auxiliary lights in the back.
