anyone had experience with these?
Cary, NC
High Performance CV axles
newfield axles ... cvunlimited claims they are stronger than stock birfs
My question is has anyone run them and also if anyone has, have you had experience with these and longfields. Im really trying to narrow down my decision, for longfields or these newfields, as the time has come to do a birf job( the 80 has 293,000 give or take a few) And I have no records of one ever being done although I find that damn near impossible. Although they could have just been repacked a few times but Im also skeptical on that.
Any advice/input would be appreciated as cvunlimited is close to home and would be cheap to ship...
Here is a Quote from the site found at another place besides the link I've provided...
"CV Unlimited is the leader in off-road CV joints and axles. George and Franklin Stuckey created the Newfield line of CV Joints and Axles when they couldn’t purchase an axle strong enough to take the abuse their Toyota Landcruisers were receiving during hardcore Off-Road Treks and Rockcrawling.
The Newfield CV joint for the FJ40 was the first Newfield product CV Unlimited introduced to the market. The Newfield has been called a birfield eliminator, a heavy-duty birfield, a heavy duty CV joint, and a high performance CV joint by numerous off-road magazines (including Toyota Trails). Our Newfield Technicians and Testers are a hard group to satisfy, and the Newfield CV Joint designed for the Land Cruiser has undergone evolutionary changes since its first design in 1998.
Why do I need to replace my Toyota’s Birfields? The problem with the O. E. design is that the joint is too small and much too hard. The O. E. joint is made to a Rockwell hardness of 70 RC, a design intended for long-term use and just getting’ around. This is great for running around town and taking road trips, but if you’ve put all the effort in modifying your truck for off-road use, why stop at the Birfields? The harder the Rockwell the better the material stands up to wear. Out on the trails, you have probably seen a birfield shattered like glass. This is the result of the metal being too hard. Getting the Rockwell hardness to a level that will not wear out too soon while remaining suitable for rockcrawling and off-roading is a fine line, but our Off-road technicians and testers didn’t mind a bit, especially when we sent them off on the weekends to test the joints and axles to failure. At CV Unlimited, we know we have built the ultimate Birfield, and we are still researching better materials and designs, so that we may improve upon the “Ultimate.
Rockcrawling needs to stand up to abuse and shock from large tires (like those 38 in size). We have solved this problem by manufacturing our joint from cryogenically stabilized aviation grade steel. The joint is then heat treated to accomplish the appropriate Rockwell hardness. The joint has been increased in size as much as possible. Some of the Land Cruisers require a little grinding to make the joint fit. The cages in the joint have been tested to be twice as strong as the O. E. parts.
We now make a joint for the FJ80 Land Cruiser that has gone through the same strengthening as the FJ40 joint. The joint is much larger than the joint for the FJ40. The size of the Newfield, when compared to O. E., is much the same, but a dramatic increase in strength has been accomplished by using stronger material, cryogenics, and heat treatment."
I think I read somewhere that these are the chromoly birfs sold by Slee, and are highly regarded. I could be wrong though - do a search and I'm sure you'll find answers.
FWIW I have been running Bobby Long's Longfields in my '94 DD for over a year now with no complaints at all - and I've really abused them! Great customer service, too.
got a shiny new one sittin in the trail bag. think they are outta of SC and occasionally youll see some on ebay. definately tempting compared to 600 for OEM. run em and let us know. Oh and btw we got two axle rebuild days coming up soon at a cruiser meeting near you if you are interested in joining us.
OK, I'm not posting up for the purpose of baggin' the CV Unlimited product, but I feel compelled to relate my (shortened) story.
About 4 years ago, the original birfs were clicking like mad - both sides. Wanted to go aftermarket for two reasons - OE co$t, and felt that strength would be better with A/market units.
Bought CV Ultd, installed them, anxiously put all back together (did both sides simultaneously). First drive out of the shop, my heart sunk to my stomach - still clicking except worse.
I called Franklin, he said he thought they had gotten a bad batch and to remove them and send them back and he would replace them - very upstanding of them except I had to have the vehicle as a DD, so I had to PURCHASE another set and then get reimbursed when they received the old set. Inconvenience but I certainly don't blame them for this business practice.
The worst part was, the second set clicked just like the first! Heart sinks lower still! Waited to replace cause I didn't have the time to do it one more time. Finally, I replaced with Longfields before my '06 Moab trip. No noise at all - tight turns, hard accel, quiet as new. Happy me! No trouble - at all - since.
Summary: Probably CV Ultd has worked out the bugs but I have a bad taste for them. I'll stick with Longfields.
Dan.
Not Bobby Longs, CV-Unlimited's the ones you were asking about.
I’ve been running both the inners and outers for well over two years now in a daily driver. I’ve driven well over 30,000 miles with no issues. See Part III of Project 80 on my signature for the install of them at Slee Off-road. Sorry for the late response, I had to dig up this tread to see if anyone had anymore questions. Looks like someone did.
Here is a link that I found...
News from the birfield front.. Longfield vs. Newfield - North Carolina 4x4 Forum
I'm installing a newfeild on a 75 fj40 that I bought 2 years ago and just now installing. Also doing the stock disc brake conversion which will allow me to install the 20-30 spline newfield (had 6 spline berfield.)
Just in compairison the newfield is a bit bigger then the stock berfield, to the point where I'm have to grind out the axel housing to install the new joint.
