anybody use these radiators ?
Overland Park , Kansas
I've been running the Denso stock replacement aluminum unit for a few years now without issue :meh:. And with RockAuto if it's damaged in transport it is super easy to return.
i thought the denso was plastic
It's the same as the stock one on later years; plastic tanks, 2 row aluminum core. The aluminum dissipates heat much better than the copper-brass 3 row radiators.
New Toyota-TRAD radiator; fits, functions, and looks correct (comes with foam seal attached). Price with discount around $400, do the job once and forget about it for the next 20+ years. Many of the super cheap radiators are made
in Chyna.
thats definitely the cheapest one
Not even close to the cheapest if you search hard. We chose this one based on core thickness and tube dissection and shape. My TYC ran about 10 degrees cooler than my nearly new Koyo.
I picked up the top one through another seller a few weeks back. Fit was almost spot on except a small amount of grinding on the side bottom mounting brackets was needed to slide into place. Cooling has been fine but as soon as I installed the ambient temps here dropped dramatically. So...probably won’t know the real result until next summer.
i bought the 2 core fyi
