Found a small old (1980s?) Norcold at a Garage sale, guy did not know much about it but said it worked, missing the DC cord, he only wanted $20 so I took it, oddly it only has one control, an on/off switch.
Got it home and in fact it works a bit too well, when first plugged in and turned on the compressor runs for about 20 min solid and then goes into a on/off cycle based on a non adjustable thermostat, that thermostat is set for below freezing, a cup of water I put in there is half frozen in less than 2 hr,
Is it a freezer only?
I called Norcold they could not get any info on that model,
I have only found one mention of it on the web, a schematic for it on the last page of this manual.
http://www.landonedwards.com/carter/files/Thetford-Norcold/DualElectricSM.pdf
I see the MRFT615B/MRFT630B/MRFT640B has a similar layout except for what appears to be an external (adjustable?) thermostat I hope I can find parts for those but they are form 1987 may not be able to,
anybody got a schematic for the new fridges? i wonder if the newer models have a dual pole thermostat?
