Any fasteners above 32mm?
Dixie co. Florida
last weekend showed me how lacking the metric side of my home tool set is, spent a lot of time looking for a 12mm wrench found at least 10 11mm and 13mm ones in the process ::)
finally found a Taiwan made 12 point 12mm and preceded to strip one of the nuts on my water pump >:(
Got a set of 6points 10-19mm off the truck yesterday looking at used sets to fill in to 32mm,
Any fasteners on the FZJ80 larger than 32mm?
Hub nuts are 54mm! Pinion nuts are pretty big-though I don't remember the exact size. The EGR pipe nut on a 60 is 36mm, but it doen't matter because you can't get a wrench on it anyway. What I've done is buy a couple of complete 6 point sets(one set for the truck, one for home), then filled in the big ones I don't have as needed. Deep sockets in the common sizes come in handy too. 12 point sockets and wrenches are the invention of the devil and should be banned.
Thanks, already have the Hub socket, I think I read here the FZJ EGR was 32 but inaccessible with normal wrenches, I wonder if a 32mm line wrench would get it (if available) I'll build up to 32 and see if I need more
Don’t ban the 12 point, at work use only 12-point tools because most high torque bolts here have 12 point heads, I can use the 12 point on 6 point stuff but not the other way around, 12 point is also handy for tight spots but suck for high torque stuff
[quote author=RavenTai link=board=2;threadid=16573;start=msg159538#msg159538 date=1084931341]
[/quote]
Must not be working on to many Cessna 150's over there...eh RT?
:beer:
R2
Raven - I think the rear lower control arms are 26, but I could be wrong. It's been a while. You can get a wrench on the EGR valve if you take out the studs.
[quote author=Rookie2 link=board=2;threadid=16573;start=msg159553#msg159553 date=1084933069]
:beer:
R2
[/quote]
nope these dont fit on Cessna's ;) , 12 point bolt head and nut, bolt scrapped for minor scuffing, forget how much the new one was but it was 4 digits IIRC
Thanks Junk, as long as it is arround 26 that will clear my 32mm plan :)
In the manual trannies there is a 36mm. And I have no clue why I still carry it. If I broke somewhere where I needed to get into the tranny I'd need a tranny jack and I don't carry one of those. Plus I'd most likely be waiting on parts. I have 32mm, 36mm , 40mm and 42mm open end wrenches but I've found that anywhere I could have used them that it was impossible to get them in there.
Does anyone knows the size equal to 54MM in case I can't get the 54MM socket?:confused:
2 1/8. They have it at Sears in 3/4 drive.
(no hijack intended)
Does using the 54MM hub socket tool make things easier/quicker/better versus using the SEARS 2 1/8 socket?
(I need to buy one or the other).
Same. The Sears socket is much more substantial.
