Any electrical gurus out there?!
Charlotte, NC
My problem started yesterday. I noticed my blinkers weren't working so I pulled the fuse out and voila, it was blown. So I replaced the fuse and noticed a different problem. Pressing on the brake pedal activates my right turn signal (just a steady light, no blinking). My right turn signal works fine. When I turn on my left turn signal, both my lights start to blink as if I turned on my hazard lights. I know a fuse just doesn't blow, but I am not exactly sure where to start on this one.
If I pull out the fuse of the turn signals, my brake still activates my right turn signal light. If I pull out the fuse for the brake light, it still activates the right signal light. Any help is appreciated!
Messed with your stereo wiring lately, or do you trust those connections (anything taped together behind the dash?)?
I had issues with blowing the circuit tied to rear lights and interior cab lights, and some of the wires for my stereo were exposed and shorting each other out.
I've see. Some crazy things happen from a sh@t stereo install. Including a much worse version of what you're describing. Check the easier things first, @pin_head is always a good source for cruiser info so start there. Then check the flasher circuit, but if it is neither, don't be surprised if it's stereo related. Too many people use but connectors and electrical tape and that's just poor form. If that's how it has been done I would redo it all with solder, shrink tube and electrical tape. On area not in tight spots I usually cover with loom and tape afterwards.
Thanks everyone, I have a list of things to check so I will get to it this weekend. I will post my findings.
