I tried to replace my antenna mast this weekend and nothing about the job worked out. In fact, its still not done. First off, the beauty nut the hold the top half of the mast motor would not spin, and after some gentle coaxing with a set of channel locks with tape on the jaws, it snapped off. The threads below were packed full of oxidized metal. The little rubber ring that holds the mast centre is fused in the mast housing, and the old mast wont come out by yanking on it like I thought it should.
No matter, I thought, so I attempted to remove the motor assembly and inspect; maybe there is a screw or something holding it in place, there is a notch in the new one after all? Then I found that the bolt stripped in the little bracket that holds the bottom of the antenna mast assembly. So I grabbed my dremel and cut off the bolt.
Next I removed the little bracket on the bottom and tried to remove the motor and sliced the top part of my thumb knuckle on the fender. It was impossible to remove the assembly without putting a slight deformation in the fender where the mast comes out of the fender. That black vinyl trim ring is now on the casualty list too.
Now I tried every possible angle to see what had to be done to get the old mast out, but I could not see anything else that could be done. I admit I was beaten by the antenna mast and opted to try again later and tywrapped it to a near by wire harness and went in the house to clean up my hand.
So, what can I do? Half of the beauty nut is still fused in the top along with the rubber ring, and the old mast wont come out. Can the top part of the assembly be removed and replaced, or am I looking at buying a new assembly outright?
Karl
Karl
