Antenna Mast Replacement Gone Wrong
Karl,
I don't know if you have seen this link so in case not, here you go -
This is what I used when I replaced the mast on my 80. I'm happy to say I didn't run into the issues you have. Although I did discover after taking the motor out and apart that there was NO old mast in there. A 2 hour job would have been a 15 minute job had I known that :rolleyes:
The biggest problem I had was trying to hold the motor etc. in place while getting the retaining bolt inserted and started. What a PITA that is.
John is the Man!
I used John's write up mentioned in the above quote. I sure as hell wish I would have known about this link 2 years ago when I first attempted the mast replacement. Ironically I had just moved to Spokane and was in John's own backyard. I spent at least 2 or 3 hours trying to replace the mast with no success. I did manage to scatch the hell out of the outer fender in the process. Upon reading John's write up, I was able to replace the mast in less than 2 hours. That included a pretty thorough cleaning of the internal gears/spool.
I didn't end up removing the mounting bracket on the motor. I was just bent it out of the way a little bit and it seemed to work just fine.
I used a piece of tape on the back side of the housing to catch the nut in case it decided to fall out after removing the center machine bolt.
I found zip ties to be very helpful throughout the process. I used them to help clean out the old grease in the gears, scoop and smear on new grease, and hold the the nut center nut in the backside hole upon reassembly.
It took a little bit of fiddling, but I eventually got the motor out of the fender. It definitely can be done but it takes patience. I actually was able to get mine pretty far out into the engine bay which made things a bit easier to work with.
Thanks to John and everyone else that contributed to this thread! I couldn't have done it without you. :cheers:
Karl,
I just completed this repair on my wifes 450 today....
The link was a GREAT help! Thanks!
I would recommend that as you re-install the motor, feed the antenna mast portion up thru the fender well and use the nut to help hold it in place - then it is pretty easy to get the retaining bolt started! :D:beer: Remember to remove this nut BEFORE installng the new antenna and to put it on TOP of the new atenna as you feed the gear toothed cable into the motor top.
Good luck to any others this was a pretty simple repar - just a little PITA since you have to do all the work at the truck & not on a work bench.
aaah, the antenna mast.... a fond spot in my heart (my first ever repair on the 80 IIRC)... :)
all the same, I'd go for a soft shorty universal antenna, the stubby bendable kind...
The same thing has happened to me . The bolt head sheared and I have totally mangled the rubber gasket where it meets the hood trying to get the rest of the nut out. Is there any hope? This was so simple last time I fixed it and now I feel like I am in way over my head.
safety message
careful yanking that antenna out, I have a him-dinger of a scar on the bridge of my nose right between my eyes from doing that on my '60 a couple years back.
wish there was a smiley with a hole in his forehead, :bang: this guy sums it up though.
I don't have a picture of the wound, but the black eye lasted a week, not to mention the heart attack I had at first when the blood was blinding my left eye.
Pic or link to this ???
Thanks
Scott
I still have not fixed mine. It turns out that the reception on the Scion radio is good enough that I dont really need the antenna. That and I have a wee bit of on my fender that I need to have repaired. When I do the repair, I will replace the antenna with a spare I bought. I have since removed a fender and have now seen how easy it is to remove compared to trying to get that damn antenna out. Never again will I do an antenna repair with the fender on.
Karl
My final solution was a manual antenna. I disconnected the power and taped the ends in case I wanted to try this repair again in the future. I also removed the antenna up down button on the dash and replaced with a CDL switch. Problem solved and I haven't thought about it again until this tread reappeared. I guess I have another item to add to the aparently endless list that gets bigger the more I read threads on this site.
I can say however that the 80 seems to be running better than ever after many of the repairs I have tackled.
Just tried yanking my antenna out, no luck. ('96) When you turn the radio on it goes up about half way on its own before you hear stripped gears rubbing. So I removed the nut and pulled on it while someone pushed the "up" botton, but it stops about 6" before the end of the white nylon cable. (compared to a new one) Don't know why it stops, wrapped the cord around my hand and was pulling REALLY hard. it's almost like there's a clip or nut on the end stopping it from coming out.
How much do the replacement masts cost? I bought a used one from a guy here and about a month after I installed it, the inner cable broke....
Go to the junk yard and get one, and while you're there watch how they remove it.
Please let me know next time you find an FZJ at a yard. And watching them remove one would be like telling a brain surgeon to take tips from your local butcher!
