I have a new antenna mast which I tried to install earlier this evening, with little success. I had to remove the motor assembly and take it apart to get out the piece of plastic 'rope' that feeds into the motor housing. Got the motor put back in, wired back up, but can't get the new antenna to feed into the motor. I made sure the teeth of the plastic are facing forward (and I tried it every other direction too). I put a lot of downward pressure on it, and tried to straighten it out first.
I tried all sorts of combinations of having someone turn the radio on/off, pushing the up/ down button while I push it in... No success.
does anyone have any other tricks for getting this mast to get pulled in?
also, I noticed while pulling out the broken piece of mast plastic, that there is some sort of yellow grease in the area where the plastic wire gets spooled up. Should I grease the new mast before I wind it into the housing?
