Antenna help
sleepycruiser
I will get by….I will survive
Asheville, North Carolina
I have read through the numerous antenna threads here and I was able to get mine out and get the plastic part out with teeth. It seems that it is still all there. So I put everything back together but I can't get the plastic twine to attach to the actual antenna. I haven't tried lowering it back into the motor yet because I wasn't sure if the plastic should be attached to the antenna first....or maybe mine is indeed broken. One end of the plastic seems a little 'notched' so I thought that would be the end that goes into the antenna. Any thoughts?
Thanks. So he hardest part is over? Now I just need to feed the new one in from the top of the hood?
Get your new one, have somebody sit inside and turn the radio off while you put the plastic toothed part down in the hole, it will wind itself down if the motor is working correctly. The teeth go towards the rear of the truck.
