Another Tire/Lift Question
Jackson, TN
With a 2 inch OME lift can you squeeze 35's under a 91 FJ80 with no rubbing? I plan on using Procomp xterrains or a simmilar large/aggresive tread design. Would that matter enough to effect anything?
Within reason, your lift will not determine whether you rub or not. Terrain, driving style and specific tire will all play a part. I have a 6" lift with 35" Toyo's and I rub all the time. My buddy had a 4-5" lift with 35" BFG Mud's and never rubbed. We live a few thousand miles apart though.
yes, technically you can, but you'll have to bumpstop it reguardless of lift height, about 2". '91's had a different style flare, so you might have a little more clearance. If you lift 2", put 2" bumpstops in, your uptravel will be the same as stock, but you'll have to get longer shocks (l's) to get your down travel back. Some on this forum say that the stock amount of up travel is not addiquate, and you should have 4-5" of lift to fit 35's. it's an a matter of oppinion, and they differ...
I'd say if you're looking for low lift and running 35's, check out
Frankie's Off Road
740 Steele Station Rd, Rainbow City, AL 35906
(256) 413-8300
Yes, get the F.O.R. lift. It was designed (ask me how I know :D) for exactly what you are trying to do...although it's more lift than OME medium.
You can do 35's on OME medium, but I think you'll want to remove the flares, and I really think a bit more lift is very desirable if you really need 35's.
It won't rub up front (flareless), but will rub in the rear at full compression. Here is a pick of OME on 35" trxus, which may be the biggest 35 you can buy for a 16" wheel, and another pic of how much travel is left to the bumpstop when the tire started rubbing the rear of the wheel well. It is about 1.25". So a 1.5" bumpstop extension should be enough for the flareless set (or trimmed flares as needed).
Last pic for comparison is the same tires on 35's (I just had them on OME for a few weeks before the F.O.R. prototype that I still run).
