Jim,I am pretty sure the sending unit from the subtank plugs into the connector at the rear center of the truck. I have a transfer pump assembly wiring harness with the connectors that plug into the white connector and the grey one located at the sill. This harness plugs into both subtank 2-pin plugs (solenoid and pump)and also plugs into the main tank from what I can tell. This harness then plugs into the 2 sill plugs (grey and white).Chris
Yes, that is correct. As the wires come forward in the floor harness to the kickpanel, they enter several different connectors (two are pictured, ID3 and the dead-end connector not numbered in the EWD.) There are 8 wires required that run from the ECU up front and using an ohmmeter you can locate them all as follows. Format is "connector name, wire color, pin location in connector and function":
-ID1, Y-R, 17. Fuel sender to gauge.
-ID3, P, 7. Dash switch.
-ID3, P-B, 8. Oz EWD says fuel filter light...probably not used on petrol models.
-ID3, P-G, 9. Dash switch. (NOTE>> EWD error. This wire shows as P-B on the diagram above and is actually P-L on the donor pigtail I have from a 1993. BUT...its in fact P-G on my truck's ECU connector and P-G up front.)
-ID3, B-R, 10. To fuse block ECU-B fuse.
-The Y-L wire is in the dead-end connector in the pic below. Ignition 12V+.
- The B-L wire is also in the dead-end connector. It connects the ECU to the D1 Data Link Connector. I think I can splice it into the same wire traveling to the DLC from the Cruise Control ECU, also in the left kick panel.
**ALL of the above 7 wires ended in their respective connectors and did not have a pass-through wire on the female side. They are also all indicated with a "X" in the US EWD, meaning they are not required by the US electrical scheme. I have extracted all 7 of these wires in tact from their connectors and will be bringing them together in a new Toyota housing, which will then be a fully grouped subtank harness to the ECU. Into that housing will connect the dash switch wiring, the sending unit wire from the overhead console and the B-R and B-W power source wires shown on the diagram that power the ECU.
- NOTE>>The B-W wire is already passing through ID2 and is the Ignition + wire to/from the ABS system, per the US EWD. Because this wire is hot with the key on in the 18-pin ECU connector, I assume it is already spliced in and properly routed into the harness so I am leaving it in its spot in ID2.
