another starting problem (real time)
Cincinnati, OH
another starting problem (real time) (update)
update section::7-26
I went to get gas, when I tried to start it back up it would click once and everything inside would just go off.
I tried a couple times, i went outside and "pushed" the cable that goes into the battery toward the battery. It started up.
I went home and pushed the pos battery cable AWAY from the battery hoping to recreate the problem, it didn't do anything it still started up.
I got my battery, and alt tested at oreily's and autozone. They are good.
I got my starter checked at oreily's, it is good.
I still don't understand exactly what a fusible link is. But perhaps I should just go to walmart and buy a replacement pos battery cable. Do you think this is a good course of action?
If you do, how long of a cable do I need, what gauge should it be, and should I get one with an inline fuse (like one you would put for an amp) or worst case could I just get a normal one that they sell.
previous post section ::7-25
As I was leaving work today my LC wouldn't start. I would put the key in, go to start it and would hear a very quick click...click...click...click....click and it would stop and the radio would go off and the gauges would just turn off.
The second time i tried it i left it on the on/acc position and noticed that the battery level was just below the half way point (is this normal) AND it was moving up and down a bit.
I pushed and pulled the pos battery cable (terminal is very clean)
I went inside, it started up and seemed ok.
I'm thinking people are going to suggest it is a fusible link, I need someone to describe what a fusible link looks like. I noticed a little black box coming from the pos cable, is that the fusible link.
I'm trying to figure this out, but my LC is starting right up which makes it hard to figure out what is wrong.
thanks ahead of time.
If a battery checks out with a multimeter it should be ok right?
Sounds like a bad connection. Clean the terminals even though they look clean. They should be tight enough that you can't move them by hand. A bad fusible link could give a bad connection as well. A fusible link looks like a short wire, they are usually located right at the battery connection, positive cable end.
-Spike
Cleaned the pos terminal, it looked fine but I did it anyways. I guess i'll have to wait until it goes out.
Agree - have the battery tested. Just call a few chain auto parts stores until you find one where they'll test it in the parking lot with a portable. Shucks does it. They like to do it because they sell a lot of batteries that way. Also, summer heat kills more batteries than winter.
DougM
update, please help
ok i will check that tomorrow, when looking at it, there does not seem to be corrosion.
Is changing the pos cable a huge undertaking? or is it just a couple bolts and a easily accessible wire.
Do you happen to have an Optima Battery? I have has similar issues with Optima. Apparently if you let the battery run down (leave the lights on or something) simply jump starting and letting the alternator charge the battery will not work unless your alternator is rated for 100 or more amps.
I do not have an optima battery.
Did you clean both the terminal and the battery post on the positive side?
Buck
The positive side of the battery acts like the main power distribution point. the negative side acts as the common return for all systems. Off the positive battery, the primary bus splits into 3 different loads. Each load is a bunch of circuits in the cruiser (The starter motor is a separate non-fused load). Each of the 3 loads is fused (called a fuse link). The fuse link is just a piece of wire that acts like a circuit breaker; however, it is very current tolerant. It is cheap and will take abuse, but will over heat and burn out if there is a real short in the load circuit.
now i see what the fusible links are, plus cdan told me
Buck
I cleaned the terminals when I started with this problem a few weeks ago. I ordered some fusible links from the local toy dealer.
