Another starter question...
So, checked my oil and sure enough it is WAY low. Small puddle of oil has formed under the rig since it has been stored in the garage the last couple of months. Dropped the flywheel cover and things look O.K. No bits of metal, teeth look good, etc. Pulled all the plugs, put the tranny in fourth and tried to wheel her out of the garage (brake is off, of course). Again only slight rocking, did not want to roll. Placed a wrench on the alt. center nut and it just spun my alt., nothing else. I can crank the fan a bit but again nothing seems to want to move. I have my buddy coming over again today to help me with this but it does not look very good right now. I am begining to realize that I may have seized my engine and I am still baffled as to how this could happen right under my nose. I seized an engine on my first Toy 4 runner years ago, but I new for weeks/months the thing was about to blow, also leaked like a sieve, and I was basically an idiot back then. I thought I was fairly deligent with my rigs mechanical upkeep, but WTF? I have barely even had any minor oil usage or leakage. I suppose it doesn't quite have the same power as it did when I purchased it a couple years ago. I may just be in denial. Engine does have 255,000 miles or so...
If, after all you've done you still get no movement/rotation of the crank....hate to say it but we've gone into the 95+/- % certainty range that she's seized up on ya. Me thinks it is time to drop pan and star looking at the bearings. Unless Poser or somebody else knows anything else to look at/try. I'm thinking the time has come to read the bearings. Sorry boss, but me thinks thats where its at now.
Yep, it's toast.
The WAY low oil was the thing that made my heart sink...I guess there were tiny signs leading up to this and from my previous expereinces I guess I was not as concerned by the minor drop in oil pressure or slight decrease in 'umphh' just before this incident. No visible leaks, still. Must have burned most of it up?
A couple friends came by today and we initially started checking wiring again. I had already pulled the flywheel cover and plugs and was still trying to determine if she was stuck. Well, we realized the engine was definetly seized. Pushed it out of the garage, poured some oil in it and rocked it a bunch and noticed the alt. spinning slightly. So we dragged it around the block and tried putting it in 4th and slipping the clutch a couple times. Before we burned the clutch we gave up. Engine would not budge.
So, I have a 2F engine, 4spd, split t-case from an '81 40 that had been rolled and is sitting in a buddy's driveway. All is not lost. This pig will live again soon.
Thank you all for your help and advice. Cheers, Carlos.
Update: I purchased an '81 2F, 4 spd, split t-case from a buddy who had a rolled parts 40. This combo was originally going to be dropped into my trail pig but because of the new situation I'll be dropping it into my other piggie. Stripped more away from the donor rig. Here are some pics, more to follow.
